Question about Gigabyte GA-M57SLI-S4 (4719331821180) Motherboard
Ram beeps codes encountered but ram not issue
I have 4 sticks of 1gb ram I was getting the ram error beep code I believe it was 1 long beep. I took all but one ram stick out and it went away then added another and it was still fine but when I added the 3rd or 4thit came back. Then last week none of the ram stick work, I called Gigabyte and they said it was the processor so I bought a new one and replaced it and i still get the ram error beep codes. Please help
  • icemanniu Oct 30, 2008
    Forgot to mention that we have also replaced the motherboard once and the video card.The error with using all four sticks still existed but again it worked for a time with only 2. I there a BIOS update that should fix this?
  • 32 Answers
It might be a bios problem but you might have the wrong ram modules so tell me first what ram does the mobo use and also what ram did you buy.
Posted on Oct 30, 2008
What do the beeps codes i am getting mean? 1 short followed by 1 long.
Beep codes don't cause or signify damage, they are just telling you something is wrong. In your case, I would say the RAM is incorrectly seated or in the wrong slots.
2 beeps Memory (RAM) not detected
Remove the RAM and press it HARD until it locks in place. Do a visual check that the indent is against the mounting.
Computer POST and beep codeswww.computerhope.com/beep.htmHelp and support with troubleshooting computer beep codes and other POST related issues.
PC Hell: BIOS Error Beep Codeswww.pchell.com/hardware/beepcodes.shtmlPhoenix BIOS Beep Codes These audio codes are a little more detailed then the AMI codes. This BIOS emits three sets of beeps. For example, 1 -pause- 3 -pause 3 -pause.
beep codes Definition from PC Magazine Encyclopediawww.pcmag.com > Tips > EncyclopediaPC Magazine Tech Encyclopedia Index - Definitions on common technical and computer related terms.
How to Figure Out Why Your PC is Beeping (Beep Codes)pcsupport.about.com > Troubleshooting Guides > Symptoms2015-10-07 · Video embedded · How To Troubleshoot Beep Codes. Is Your Computer Beeping? Here's What to Do. By Tim Fisher. PC Support Expert Share Pin Tweet ...
Jan 23, 2016 | Computers & Internet
4 beeps on start up but no screen
four beeps is ram I believe. Take everything off and see if it starts and then put stuff back one at a time and see what is causing the problem
Oct 01, 2013 | Dell XPS 200 PC Desktop
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
N1996 motherboard 4 fast bios beeps
The beeps actually refer to memory not just RAM, it could be the memory on your graphics card or the cache ram on your processor. Or it could be a compatibility issue between memory sticks.
Sep 18, 2012 | MSI Computers & Internet
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Can not reinstall os on mt acer 246lc it bleeps 4 times and swithes off
Without knowing what motherboard is in the unit - it will be difficult to determine what the 4 beeps means.
Generally, 4 beeps means issues with :
- memory
- video card
- keyboard
- motherboard failure
Things to try -
- make sure there is no keys stuck down
- remove the battery and AC adapter, remove and re-install the memory sticks (reseating the memory)
If this does not work, your problem may be more serious. Let us know the results of the above suggestions.
Nov 17, 2009 | Acer Computers & Internet
One Short beep and two long beep
The beeps you hear are BIOS Beep Codes. Sort of like a Morse code, if you know what that is. Every computer has it's own BIOS program, and version of that program. Each BIOS has it's own Beep Codes.
Taking a guess, as I don't know what BIOS program or version you have, it sounds like a ram memory issue.
Suggest you,
1.Unplug the computer
2.Open the computer case
3.TOUCH the metal frame of the open computer case, to relieve you body of Static electricity. Static will silently fry out your delicate computer hardware components. You won't see it or feel it.
4.Remove the ram stick/s. Reinstall the ram stick/s. (Stick/s means one ram stick, or two, three, or four ram sticks)
You may have just had a loose ram stick.
Apr 28, 2009 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Problems with Foxconn 6100K8MA-RS Motherboard memory upgrade
This is an oldtime POST code memory error. Likely that ram is either installed wrong, bad RAM or the mobo doesn't like one of the memory sticks.
See http://www.computerhope.com/beep.htm.
You must count the beeps.
Mar 17, 2009 | Foxconn 6100K8MA-RS Motherboard
Gigabyte GA-M57SLI-S4 (4719331821180) Motherboard Logo
234 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
