Question about Neff H5470 Microwave Oven
Lost instruction manual as to how you reset time on clock
Built in Microwave Neff H5470n0GB/3
How do I reset the day clock as i have lost this part of manual?
  • 4 more comments
  • Ham9447 Oct 30, 2008
    The Link you gave me I cannot download, page comes up as the page cannot be found. Any other way?
    Many many thanks above clock problem now resolved. Gold stars all the way.
  • Anonymous Mar 29, 2014
    Drive coupling sparks and is burnt. Metal Sorrounds also charred. Would replacing the coupling be enough?
  • Anonymous Mar 30, 2014
    This model does not appear on the neff site.
    A PDF or link would be appreciated.
    I need an instruction manual for neff microwave
    Need instruction manual PDF for neff microwave H5453nogb. This model is not on the neff web site
    President:
  • 2,712 Answers
Go here to download to your manual:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 30, 2008
I need instruction manual for Neff microwave oven model 5969
Use link, enter full ENr from rating plate and you can download PDF of manual
Dec 08, 2012 | Neff Microwave Ovens
Lost user manual for a neff microwave oven h5642w0gb04
go pleae to www.fitness.manualsonline.com or www. retrevo.com
God bless you
Jul 16, 2012 | Microwave Ovens
My neff microwave 547 switches it'self off after 25 seconds
Any repair to a microwave should only be carried out by a competent engineer as even when the unit is unplugged there is potential for a large amount of voltage to be stored by the capacitor (which in the case of this model is part of the inverter board). I suggest that you bite the bullet on this one and organise a call from the manufacturer assigned repairer.
Sep 09, 2011 | Neff H5470N0GB Microwave Oven
How do I set the clock? I've lost the
That would depend on the microwave. Most new microwaves have a 'clock' button on the front face. Normally, you can hold this down until it prompts you to enter the appropriate time.
Jun 08, 2011 | Microwave Ovens
My h5470nogb/03 900 watt microwave cuts out after 20 seconds what is the problem please
Possibly the magnetron is not producing power and as the cavity temperature is not rising, it cuts out.
Is there an error code in the display?
Jan 02, 2011 | Neff H5470N0GB Microwave Oven
Why does my microwave oven keep cutting out and clock needs resetting before it can be used again
Check the screws in the mains plug and the wall socket. If there is no problem there, check the fuse holder in the microwave itself for bad contacts.
Hope this helps.
Nov 04, 2010 | Neff H7881N2GB 800 Watts Convection /...
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Locating the mangatron fuse for a Neff H5470N0GB
I have never heard of a "magnetron fuse". Fuses are easy to locate on microwaves, though. The easiest way is to follow the power cord from where it enters the oven's frame to where it terminates on the board. There is a fuse in the immediate vicinity of the termination. You can check the fuse with an ohmmeter...it should read zero ohms, anything else means the fuse is blown.
If your oven is blowing fuses that means there is something else wrong with it, most likely the magnetron. You can't miss the magnetron, it is mounted on the side of the cooking cavity, you can identify it by its heat fins. If you want you can trace the wires from the magnetron back to the board, there usually is no fuse in that line but a capacitor is always in that line. Check the capacitor as well, if reads zero ohms it is bad and it is what needs to be replaced.
I am curious as to what is going on with your oven. Do the lights and fans come on but it doesn't heat or is it completely dead, no lights, no display, nothing?
Either way, I am including a link for you to a site that has all the parts and accessories you need for your model microwave. I hope this helps, here is the link: http://www.espares.co.uk/parts/microwaves/neff/h5470n0gb%2f02/p/1095/1126/0/553422
Sep 24, 2009 | Neff H5470N0GB Microwave Oven
Microwave turns itself oo
it sound like the inverter unit is faulty or the magnetron is gone.the only real way to find out which is to change each one in turn,sorry i cant be any more help.if you have any more questions get back in touch,regards les
Jul 28, 2009 | Neff Microwave Ovens
Neff H5470 Microwave Oven Logo
1,548 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
