Question about Panram International Panram 256 MB USB Crystal Bar (FD0002AU) Media
Write-protect cannot be removed
A friend of mine borrowed my Panram USb fdisk, and when she returned it, i couldnt save any file anymore nor erase something from it. she explained that she mistakenly remove the fdisk with removing it safely. can anyone help on these? itried to reformat the fdisk, but its unsuccessful. pls i hope u can help me on this problem the soonest. my fdisk is of much help for me. God bless jonathan
    Scholar:
  • 41 Answers
I have a few suggestions for this, but when I give solutions, I always give them in an order of safest to most difficult(or potentially damaging). It would be in your best interest to try these in the order I give them: #1 (assuming you have xp if you're using a usb 2.0 device) Go to start>run> type "cmd" to get a command prompt. Type "CHKDSK" and type the drive letter of your Pendrive and "/F" (example-"chkdsk E: /F") and hit enter. You will probably get alot of errors as it checks the disk and once its free of errors, formats it. When it's done, SAFELY remove the drive, and plug it in again. If that doesnt work, try number 2 #2 DO THIS AT YOUR OWN RISK! You are about to enter the registry. If you do not know what you are doing in the registry, do not go in there. Also, you should know how to back up the registry before you go in. If you do not know, this solution might not be for you. Start > Run > type ?regedit? - Go to the following: My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDe vicePolicies - Double click on the string ?WriteProtect? and change the ?Value Data? box to ?0?
Posted on Sep 16, 2006
    Problem Solver:
  • 19 Answers
Before trying to formate and all those.. check this first. Most of these flash drive has a physical switch to protect from accidental deletion. So look around see if you can find a switch and switch it to the other possition. Usually this switch also accompany by a lock symble.
SOURCE:
How do you erase hard drive
A hard drive is the brain of a computer. However, over time, that brain can become overworked and overly saturated with old software and outdated information. It becomes clogged and needs a fresh start. By erasing a hard drive, you can give your PC that fresh new beginning. With a few steps you can erase your hard drive manually, without the aid of expensive software.
Make sure your data is protected before you proceed. Whatever you do not save will be lost once you erase the drive. Use a CD or jumpdrive to save your information. Boot with a system disk. Before you continue to erase the hard drive, use the system to create a system disk. Use a 3-1/2 inch floppy disk and format it with the command "format a: /s"; this will create a bootable disk that contains system commands. Place it in the drive of your system and turn it off, then back on. Reformat the hard drive. Once you've booted with the system disk, type "format c: /s"; this will reformat the hard disk, virtually destroying the old hard drive you used to know. Depending on the of the drive, the formatting may take a fairly long time. Once the formatting is over, use the command "fdisk" to create partitions (which are logical sections for your hard drive's storage). Given the newer hard drives and operating systems of today, you can fdisk the drive and use all of the space. or if you dont have a floppy drive Download a disk wiping utility, such as Darik's Boot and Nuke (DBAN) or KillDisk. DBAN is an open-source product, while KillDisk is available as a free, closed-source download. http://www.dban.org/ http://www.killdisk.com/ Once you download the file, save it to your computer somewhere easy to remember. Insert a blank CD into your computer and use a CD writing program to burn the hard disk wipe utility to the blank CD. If you are using Windows Vista or 7, there is a built-in utility that will perform this task. Back up the data on your computer that you want to save, if necessary. Insert the CD that you created into the computer that is attached to the hard drive you wish to erase. Power on the computer and choose the setup option to boot from the CD. Once you have booted from the CD, you will enter into the hard disk wipe utility. Depending on which utility you chose to use, this screen will vary, but the choice you want to select is to erase or wipe a disk drive. Choose the hard disk that you wish to wipe and confirm that you wish to permanently erase the data on it. Before confirming this, you may wish to physically double check and ensure that you are erasing the correct drive. Once you start the erasing process, it cannot be halted, paused or reversed. You will have to wait for anywhere from a few hours to even a few days for the process to complete, depending on how large your hard drive is.
Hope this helps.
Dec 20, 2012 | Computers & Internet
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Hi there. I have an Acer Aspire 5600AWLMi, I want to format my laptop and start everything from scratch; reinstalling XP and all the drivers in it. Two problems: 1.Don't have the Acer Recovery...
You need to replace the DVD reader or use an external one, and obtain a windows install CD. Enter your model number on the acer website to get all of the required drivers. Obtain the drivers and put them on a CD before reformatting as you will not have the wifi drive to go get the drivers if you try and get the drivers after you format.
May 11, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
I have a 2 gb usb drive and it has a corrupted boot sector so i cant save data and also cant format it . I tried to format it using various data erasers (kill disk , driverestore professional , . . etc)...
dear friend
try using HP Format Tool to format that.
http://en.kioskea.net/download/download-127-hp-usb-disk-storage-format-tool
OR
http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
if this helped then ok otherwise your usb key is totally corrupted
Thanks
Gagan Gupta
Mar 23, 2011 | Computers & Internet
WRITE PROTECT
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format FDISK
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Sep 01, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Windows says not enough space on pny 8 gig flash drive
Try formatting the drive as NTFS instead of FAT32 (assuming you are using it only on Windows computers). FAT32 doesn't support files over 4GB.
For more info, see http://www.google.com/search?q=fat32+file+size+limit
Feb 08, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Nintendo DS Lite - How do I delete points from a game?
If you want to delete the points you have to delete the whole save file also. Thus, you have to copy the game and the save file into his friend's ds if he wants to play the same lvls that your son has passed. PLEASE rate me.
Oct 11, 2008 | Nintendo DS Lite Console
PNY Optima Attache 2gb
this program for another USB flash drive worked for me
(took me two tries for it to work)
http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
http://usa.apacer.com/us/support/downloads.asp
Download type: utility
Product Type: USB Flash drive
May 14, 2008 | Electronics - Others
No system settings
By "system settings" I assume you mean the drivers or software for the MP3 player. Re-Install from the manufacturer's cd supplied with the device...
Aug 31, 2007 | Panram International Panram 256 MB USB...
Panram International Panram 256 MB USB Crystal Bar (FD0002AU) Media Logo
659 people viewed this question
Top Panram International Electronics - Others Experts
Marvin
Marvin
Are you a Panram International Electronics - Other Expert? Answer questions, earn points and help others
