Lexmark2300 Series I have purchased a new lap top a Toshiba L350/350D. I am trying ti install the above software but it does not appear to work. Will it be out of date or not compatible with this lap top? Thanks Susan
    President:
  • 2,712 Answers
Go here and select your OS and download the driver:
http://search.lexmark.com/printer/US/en/23D0900
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 30, 2008
My Toshiba Lap Top does not show Model X2500 printer to be installed. This printer was used in an Acer Lap Top before and it was duly installed . I still have the disk.What can I do..? This Toshiba is...
Great news that you still have the disk. You can use this disk to install the drivers for the printer on as many computers as you want to use this printer. For now, tho, you can install on your Toshiba laptop by placing the disk in the laptop's CD drive and follow the prompts on the installation menu. There is no need to uninstall from the Acer. The driver is not like Microsoft software where you only have one key for each installation. You might also be able to get the drivers from the Lexmark website.
Jun 20, 2011 | Lexmark X2500 All-In-One Printer
I just upgraded my ti89 and now it will not detect in windows 7
I'm going to take it that your Ti 89 upgrade is a Ti 89 OS update. Check and make sure your Ti 89 OS is up to date with with OS 2.09v. For ti 89 Titanium your OS should be 3.10v. To check the version of your OS from the home screen press, [F1] [A]-About. The OS version should show up at the second line from the top of the "About" window that pops up. If you don't have the updated OS version you should go to the Ti web site and download it. Now let's try getting the computer and calculator connected.
When you have your computer and, Ti 89 calculator connected the calculator should be on and, at the home screen.
Procedure 1.
Go to your Start Menu and search for Device Manager.
Open up Device Manager.
Scroll to the USB controller and click the +. Turn the calculator ON then connect the USB cable to your PC. A new device will appear on the USB controller.
Right-click on the new device and, choose Update Driver Software. The Hardware Update Wizard will appear.
Choose "Browse my computer for driver software".
In the search field type in C:\Program Files\TI Education\Driver Files. Look for the tiehdusb.inf driver file.
Click on Next to finish installing the driver properly
Once the driver is installed click Finish.
Procedure 2.
Now click on the "Ti Connect" software on your desktop. Double-click the Ti Device Explorer located to the left inside the Ti connect window.
The software should start looking for your calculator. A pop-up should display looking something like what is pictured below. Under device your calculator should display. If your calculator is located the software will highlight on to it. Click, "Select" and another window should pop-up.
The next pop-up should look something like this. If your Ti 89 is present it will show up next to device and, probably won't say Titanium. Your cable type and port should be listed too.
If all the information is correct in the window that appears click "OK" and, you should be able to start downloading. You can skip the rest of the procedures. If your Ti 89 still won't connect to the computer goto Procedure 3 unless you have already tried Procedure 3, then goto procedure 4.
Procedure 3.
If the above procedure still does not help then try un-installing and, re-installing the Ti Connect software. After un-installing re-boot your computer. After re-booting your computer you can get the latest copy of Ti Connect software by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti Connect software" At this Ti site under "View: Connectivity Software", Click, "the OS link that applies to your computers operating system". Next, click the Download Item, "Ti Connect software for ....OS". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti Connect software for ....OS will be download to you. Click, "Save" and then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, 'Save as" to this folder, "Desktop."
Next right-click the Ti Connect executable on your desktop and select, "Properties." Then click the "Compatibility" tab located at the top of the "Properties" window. Click the box next to "Run this program in compatibility mode for." and select "Windows XP Service Pack 2" from the drop-down menu. Click "Apply" and choose "OK." Double-click the TI Connect executable and select "Next" to begin the installation. Click "Yes" to OK the installation process to proceed. Then click "Finish" to complete the installation. Next, reboot your computer.
Now go back and try Procedure 1 and 2 again. If you have already tried Procedure 1 and 2 twice, go to Procedure 4.
Procedure 4.
If the above procedures fail then try a different cable and if possible a different computer.
If trying different cables/computers fails, please contact and fill out a Ti Cares Customer Assistance Form. You can get there by clicking this link, " Ti Cares Customer Assistance Form "
Attach a system information file to the email reply you receive from "Ti Cares Customer Assistance Form."
To get the system information file:
Go to Start Menu and search for System Info
Once loaded, click on File and choose Save
Name the file FirstNameLastName.nfo
Please check to make sure that system info file(.nfo) is the selected type of file.
Attach the .nfo file to the email reply
Jan 03, 2011 | Texas Instruments TI-89 Calculator
No picture on lap top lcd
Do me a favor get a light source and hold it up to the screen if you can see your operating system your screen is shoot...
Feb 23, 2009 | Toshiba LCD Display for Satellite Pro...
Acer aspire lap 4720z web camera is not installed,.How to install
go to acer.com and download the driver for it along with the software if needed.
Nov 14, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Toshiba web cam PA3554U-1 video not working sound fine
The same thing happend to me. I, unplugged the cam. reinstalled the drivers from the toshiba cd. rebooted. plugged my cam back in. and It was working normally again. Then I reinstalled livemessenger rebooted again and everything is worked fine. Good luck with it mate.
Nov 14, 2008 | Toshiba PA3554U-1CAM Webcam
I have a HP PSC 2350 series printer scanner fax and can not get it to load on my new microsoft Vista lap top. How do I do this
Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=421997&lc=en&cc=us&dlc=en&lang=en&cc=us to have the utility check your system to see if the proper driver is installed.
It is difficult to understand your exact problem from the description that you "can not get it to load", but I would further suggest, if the above process does not solve it, go to http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=38475&lc=en&cc=us&dlc=en&product=421997&lang=en, which presents two specific resolutions. Both are related to installation of the software that came with the printer, and it appears that if this is done properly, the printer should function without issue.
Finally, any remaining issue can be directly resolved by working through online chat directly with HP, while you are at the machine you are trying to connect the printer to and working with one of their techs. This should provide you with resolution, and thank you for rating FixYa!
May 04, 2008 | Computers & Internet
TI-84 PSE: Stuck on waiting... please install operating system now screen
The best way to solve this problem is to get a 2nd TI-84 to link into with the linking USB cable. Then turn on working calc press the 2nd button then link button (or the XTON) variable button. Scroll up to option G: SEND OS "DO NOT HIT ENTER YET" and then remove and replace one battery from the non-working unit. NEXT press enter on working unit to SEND OS.
Oct 18, 2007 | Texas Instruments TI-84 Plus Silver...
37 people viewed this question
jasbo
jasbo
