Question about GE Kitchen Ranges
Range Model RGB745GET1AD, Oven (bake) will not light, but the broiler will light a work fine. Please help Thanks Mark
  • 59 Answers
You most likely need a new ignitor. It is located on the back of the cabinet and is pretty easy to change. The part number for that model is WB13K03. Good Luck!
Posted on Nov 02, 2008
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 06, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Hi...need help with my oven it won't heat up
If your surface burners work and the broiler operates normally, more than likely you have a failed igniter on your bake manifold. There are two separate igniters on your oven. One is for bake, and one is for broil. This is a common failure, due to the fact that the bake function gets used more often than broil. I found your part listed at repairclinic.com. Just type in your model number and the igniter is listed as item number 1990. For instructions on how to replace the igniter, click on the following link:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Just make sure you turn off the gas and unplug the range before starting any repairs. If you require further assistance, please let me know. I hope this information is helpful to you.
Jul 13, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
OVen doesn't Heat
More than likely, you have a bad igniter for the bake manifold. Since the gas range has a separate ignitor for the broiler, this explains why the broiler works and the bake function does not. Since most consumers tend to bake more often than broil, the bake ignitors go bad more frequently. There are a couple of different ignitor types listed for your range. I will need an EXACT model number (located somewhere around the oven door opening) before I would be able to give you a correct part number. The ignitor price varies between $52 - $64. If you wish to make the repairs yourself, I can give step by step instructions. Please post back with your information and I will be able to assist you further.
Jan 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
