Question about Panasonic Televison & Video
I have a Panasonic DMR EX77 PVR. Two days ago the Electronic Programme Guide stopped working and was replaced by the message "No Data". Is this a unit failure or just a temporary problem with the transmitter?
It must be no coincidence that our Panasonic DMR EX768 has done exactly the same exactly 2 years later i.e. on the weekend the clocks go back. We intend to reset the time & see if that solves the probelm
Posted on Oct 31, 2010
  • bryn gomer Jul 17, 2011
    I have the same problem with my Panasonic DMR EX 85. Everything is working fine except the EPG which shows no data. Any suggestions?
My panasonic dmr ex77 is not multi region. How can i make it so?
The procedure below is a hack , can interfere with the normal working of the DVD player
*** Please note *** You will need a laptop with an Infrared (IR) port to use this method.
Most modern laptops have now dispensed with IR ports in favour of WiFi and Bluetooth, so you may need to forage around and find an older laptop with IR.
1) Download both parts of Chachi's RAR file (both of these files can be easily found on this forum).
You will need both files, as the ISO image file has been split across two compressed files.
2) Using WinRAR or WinZip unpack the ISO image file to a folder on your hard disk (the desktop is a good place, so you can easily find it later).
To successfully unpack the ISO image file, both of Chachi's RAR files must reside in the same folder.
As you extract the ISO file from the first archive, WinRAR or WinZip will automatically move to the second file and continue the unpacking process.
After the unpacking process has completed you will be left with a single file with the extension ISO.
3) Using Nero (or similar), use the "Burn Image to Disk" feature to burn the ISO CD image onto a blank CD (just copying the ISO image file onto a CD will not work).
I used Nero to achieve this, but most CD burning software can do the same.
4) On the laptop, ensure that the IR port is set to COM2 in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
Try to select an older IR mode if available.
My old Toshiba Satellite 4030CDT only supported FAST IR modes and wouldn't work.
I then switched to an Acer Aspire 2000 and through trial and error found the "IrDA (HPSIR)" mode worked perfectly.
5) Boot the laptop from the CD
If your laptop does not give you the option to change the boot drive order at POST, you may need to temporarily change your boot drive order in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
6) When the laptop has sucessfully booted from the CD you will be presented with a menu.
Using the down cursor key, select option "4. Minimal Boot" and press return.
7) At the "A:\>" prompt type "cd winamp" and press return.
8) At the next prompt "A:\>WINAMP\" type "winsamp" and press return.
9) The Remote control test tool should now be loaded (blue screen with white text).
10) Press the "r" key to load in the REMOTE.TXT file (this file contains the IR signal information required to reprogram your DMR-EX77).
11) The captions "button 1" to "button 10" near the bottom of the screen will now have changed from white to pink.
These are the emulated buttons you will need to press in order to unlock you unit.
Ensure "button 1" is highlighted before proceeding to the next step.
12) Power on your DMR-EX77 and switch it to DVD mode.
You must ensure the disk tray is empty during this process.
I had my disk tray empty and ejected (sticking out) during the process just as a precaution.
13) Point the IR port on your laptop at the IR receiver on your DMR-EX77.
The IR port on the DMR-EX77 is located just above the DVD/CD Open/Close button on the right of the unit.
I found the optimum distance between the laptop and the infrared receiver on the DMR-EX77 was approximately 5~6 centimetres, any more and it may not work.
14) With the IR ports aligned and "button 1" highlighted in pink press the return key on the laptop, wait a moment, cursor right to "button 2" and press the return key, wait a moment, cursor right to "button 3" etc....
Keep repeating this procedure until you have entered all buttons highlighted in pink from 1 to 10 in order.
If your DMR-EX77 reacts as mine did during the process you may see the display on the DMR-EX77 change and also experience the TV channel changing.
Don't panic as this appears to be quite normal during the unlocking process.
15) If all has gone well the display on the DMR-EX77 should now read "HELLO" and you should hear the hard disk spin down for a second, then spin up again.
The DMR-EX77 has new reset itself and has successfully been reprogrammed.
Leave the unit alone for approximately 10~15 seconds before doing anything else, just to be on the safe side.
16) The buttons on the front of the DMR-EX77 unit will no longer function, so switch the DMR-EX77 off using the remote control.
If you left the tray poking out during the reprogramming process (as I did), just wait a few seconds and it will close automatically, you can then switch off the DMR-EX77 using the remote.
There is no need to disconnect the DMR-EX77 from the mains supply.
17) Switch the unit back on, pop in any region DVD you like, sit back and enjoy biggrin.gif
Switch off your DMR-EX77 using the power button and leave it off for a few seconds.
Switch back on your DMR-EX77 and when it's ready try the proceedure again.
I failed several times initially, but it didn't seem to do any harm and everything is fine.
You may also find that changing the IR mode setting in your laptops BIOS may help.
I had to try a few different modes until I found one that worked.
If you can't find the files you need, or require the procedure for using another type of device to region free your DMR-EX77, then visit: user_offline.gif
Apr 22, 2008 | Televison & Video
I have a panasonic dmr ex77 and it has suddenly stopped working. when you turn it on the dvd tray ejects and the display shows HDDERROR
Good day!!!!
that problem is cause of malfunction/defective HDD or hard disk inside...
please try to open the cover and remove connectors on hard disk then power it ON..wait for showing of display...
after that power it OFF again and after 1 minute reconnect the connectors of hard disk..then try to power it ON again..
if the problem persist...the hard disk is corrupted you need to replaced it..
Jul 24, 2011 | Televison & Video
I've had a Panasonic DMR-E85H since 2005 and it's always worked great. Several weeks ago when I pushed the button on the romote to start the machine, it went through the normal startup & self-test then...
My E85H went totally out the other day. Had been experiencing the dreaded 'please wait' syndrome for the past month but started working again. I e-mailed Panasonic and they told me to send it to;
McAllen Service Center
4900 George McVay Dr.
Suite B Door #12
McAllen, Tx 78503
Said it would take 2 - 3 weeks, include a note explaining the issue. They do not need the power cord or remote. Also said charges would $50+parts+shipping. I assume labor will be higher after they determine what the problem is.
Have you looked at this thread I followed the well written advice/instructions, took mine apart tonight and found 3 bad capacitors which I will be replacing tomorrow. If I have the luck that the others have reported my unit should be up and running tomorrow night for under $10 and a little time. Hope this helps.
Mar 14, 2010 | Panasonic DMR-E85H DVD Recorder
Since it went into "disk recovery mode" it now will not play dvds
Got the same problem. Happened 2 months after guarantee expired. **** machine. The only good thing is the harddrive and that is made by HITACHI not Panasonic! I go Sony next time. Panasonic quoted £200 plus to fix the problem. I only paid £220 when I bought it new.
Sep 13, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Green Aura around everything including menus
Have you recently put speakers or something with magnets near the the tv??
Apr 30, 2009 | Televison & Video
You can get the full instructions here
That is the whole booklet. Please let me know if you have any problems
Jan 10, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Making my Panasonic DMR EX77 multi zone
i have the same player and wont play burned dvds
Sep 05, 2008 | Televison & Video
Multi region code for DVD
You need to hack the dvd reinstalled firmware, I can see if I find hacked firmware for your dvd
May 01, 2008 | Onkyo DV-CP704 DVD Player
How do I flash the firmware for a Panasonic DMR-EZ47V?
According to the Engineering channel schudle there is a new firmware (v.1.13)for the following panasonic models
Jan 31, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
381 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
