Question about Dell A215 Computer Speakers
Speakers well i brought new speakers n plugedd them and everything is plugedd fine and the cord in the back of the computer also is fine and the speakerss turn on meaning the power light is on but when i look up a song to listen to i cant hear anything what is the problem? what should i do?
  • 189 Answers
Good day!
Did your computer installed the audio driver? Usually you know if you have installed the audio driver once you see a speaker icon at the bottom of your monitor or at the task bar. If not installed it first. If there is maybe the speaker was not activated, so you have to double click that icon, at dialog box will appear, click option then properties, activate the speaker.
Hope that solved your problem.
Thanks.
Posted on Oct 30, 2008
Altec lansing imt620 no sound, everything else works fine (speakers are ok)
Pardon my question; but what do you mean everything works fine? Have you attempted to attach the speaker system to an other device, such as a Receiver, DVD player, TV, etc? First check and see if the System works on other electronics and if it is working, then you go back to your computer and start from there; and I assume "everything works fine" could be the computer. The Altec is one of the best systems out there and their quality superior. It is rare to get a new Altec in a defective state as they do a great job on quality control.
Dec 19, 2013 | Altec Lansing 4.1 140 WATTS SPEAKER SYSTEM...
Everything is plugged in turned on but no sound. I recently moved my computer system to a new location and have not been able to get the speakers to work help
I assume this is a powered unit, so first off make sure the power cord is plugged into the wall and the speakers. then make sure you are plugged into the correct jack on the PC. It is usually green in color. Finally, make sure the volume on both the speakers and the PC are turned up. Report back wit hresults.
Jul 01, 2011 | Harman Kardon Audio Players & Recorders
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
Logitech speakers hissing only when headphones plugged in.
The headphone adaptors attach to your computer has a
loose connection. Use another headphone and try.
Send in your e-mail and vote for the solution. Thanks,
Sep 27, 2009 | Logitech X-540 Computer Speakers
Logitech z2300.
Make sure you you have turned on both of the power buttons the one on the remote should be pushed down and there is also one on the back of the subwoofer just above the power cord connection. Hope that helps if not just let me know
Nov 28, 2008 | Logitech Z-2300 2.1 Computer Speaker...
Logitech PC Headseat
Hi again,
To your new concern:
  • pls verify that in "Sound, video and game controllers" in the Device Manager, there are no yellow or red marks;
  • check that all the drivers are installed;
  • thereafter, double click on the speaker icon in the System Tray.
  • on the new Speaker window, click on Options, Properties, Playback, check "Microphone", OK, uncheck "Mute" and slide the control up to desired mic level;
  • click again on Options, Properties, Recording, check "Microphone", OK, uncheck "Mute" and slide the control up to desired mic level.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 06, 2008 | Logitech R-20 Computer Speakers
Logitech x-230 - left speaker not working when used with 360
my speakers plug into my comp. by that little cord with the green end piece. and i have to figit around with it just to get one speaker to work, can i fix it or do i have to buy the whole set again?
Mar 10, 2008 | Logitech X-230 Computer Speakers
Sound cuts out when you touch the cord???
bad cable shorted out in it can u get new cable or under warenty for 1 yr ?
Jan 09, 2008 | Logitech Z-5500 Computer Speakers
The volume buttons dont work
i think your wireless speaker is bad or had a factory defect.my suggestion is to return that speakers to the store if they warrant because they will replace it a new...
Dec 15, 2007 | Brookstone Outdoor Wireless Speaker...
Dell A215 Computer Speakers Logo
29 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
