Question about Samsung ML 1610 Laser Printer
My computer restart when I print something
Dear Sir ! Kindly solve my problem I can't understand any thing about this problem. I have used this printer for a period of two months but never come such dreatful problem. Now When I want to print some document my computer restart immediatly and the printer print only " Internal Error-false Position: 0x1c462 (115810) system : H6FWSIM/xl_image Line : 605 Version : QPDL 1.26 04-14-2005 "
  • 161 Answers
Reinstall the printer drivers. In your case, I recommend erasing completely the previous driver so you do not overwrite on them. This is just in case you have a bad sector in your hard drive, we do not want to reinstall over a bad sector. After the driver is erased, check your hard disk with the scandisk or chkdsk utility. Then reintall your driver from start.
Posted on Sep 21, 2007
DEAR SIR, I CANNOT ABLE TO PRINT THROUGH PRINT SIR PLUS 10/100 PRINT SERVER (PS1203) THROUGH NET WORK. I CONFIGURED EVERYTHING BUT I CANNOT ABLE TO PRINT. REGARDS BASHEER
If you have configured every thing correctly , the problem may be with the network cable. There are (2) types of network cables are available.They are 1). cross net work cable ,2). Parallel network cable. I think you have used the parallel network cable. Now try to purchase the cross network cable or you may prepare it if you are awre about it. Hurray ! your problem will be solved automatically.
Even though if your problem is not solved , kindly follow the instructions as follows;
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ). According to above addresses, you have to complete the networksettings of your printer by mentioning the different IP address .
To find out the above mentionedaddresses first open the control panel -> network connections -> local areaconnction -> properties -> Internet Protocol Version 4(TCP/IPV4) ORInternet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection asmentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , thegateway may be 192.168.0.1 Or any number. And the subnet mask may beXYY.XYY.XYY.0.
Accordingto your ISP addresses you have to complete the network settings of yourprinter. First press the additional functions -> system settings ->network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your networkconnction with the printer to your computer will be automatically solved.
Sep 28, 2010 | Edimax PS-1203 Print Server
Once a document prints, it stays in the print spool as printing, thus not letting anymore documents print. Have to reboot the computer to get it to clear out.
Kindly go to run in the start menu,type in services.msc and then click ok. The list of services will open up . Kindly go to print spooler,highlight it and then on the left hand side click on stop the service and then click on restart the service after 1 minute,restart your computer . your issue will be solved.
Sep 21, 2009 | Kodak ESP 5 Printer
When I print something, I get a completely not understandable text. ít seems like my computer show me an english text and somewhere between computer and printer a weird translation takes place....
what is your printer?does your printer use LPT port or parallel port,if your printer do have a USB port better use it than the LPT port.If dont have usb port then reconnect the LPT port firmly both on the printer and your cpu.
Sep 12, 2009 | Office Equipment & Supplies
Respected sir, I am a electronics engineer .
You don't have any problem at all, laptop DVD/RW's write slowly anyway as opposed to to a desktop DVD/RW.
Remember one thing my friend, the slower the burn the better quality the burn will be because the burn is better and deeper at 4x rather that at 8x or 16x
Regards.
Jul 29, 2009 | Computers & Internet
Physical dumping of memory
Hi!
Take out the RAM and clear the fungus..
fix the RAM and start with safe mode....
Bye & Take care...:)
Mar 13, 2009 | Microsoft Computers & Internet
Printing problem
what operating system are you using for..
- sometimes its one of the problem when d fonts is small
- use the windows fit to your printer.. can help solve your problem
Aug 26, 2008 | Matrix Dot- Printer 435
Working of negative scanner
The Manual explains all
There is usually a full user guide and manual on the software disk in PDF format.
The only way is to sit down and have a good read
Feb 01, 2008 | Office Equipment & Supplies
Medion AE19E1 (second hand)
sir,,i think theres something wrong with the power supply,,,kindly checkthe power supply of it,,,thanks and hope to help you thnkss??
Jan 28, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Samsung ML 1610 Laser Printer Logo
364 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
