Question about HP Office Equipment & Supplies
The red triangle is blinking - HP Office Equipment & Supplies
    Sniper:
  • 87 Answers
Model No Please and when do you get this error.
Is the printer able to come to ready state.
Does this error comesback when you are trying to print a copy. Please provide more details
Posted on Oct 30, 2008
SHARP AR-5520 RED TRIANGLE LIGHT BLINKING HOW TO SLOVE THIS PROBLEM?
If the triangle of dots points upward it needs toner, if the triangle points down the machines waste toner needs to be emptied out.
Apr 27, 2017 | Sharp Office Equipment & Supplies
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Red triangle on left hand top corner - K800i
hi
triangle means roaming if its a red triangle then your internet is turned off while roaming
go to options>mobile network> data services and select what setting you would like either on all the time, off, or off while roaming
solid triangle means extended network (coverage with another carrier that your service provider has an agreement with). some services might not work
blinking triangle is roaming (on a network with no agreement)...most carriers have simply disabled roaming entirely, you either get their network, or extended network to avoid additional charges. int'l roaming is different, not restricted. if you're near either of the borders, i'd say choose "home only" under network options to avoid int'l charges
Hope that helps
May 25, 2009 | Sony Ericsson K800i Cellular Phone
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
124 people viewed this question
Seeker5211
Seeker5211
