Question about Gateway (2500068) Motherboard
Laptop shutdown monitor shut to soon / stuck in sleep mode
O.k heres the problem: usually shutdown on laptop is normal but if i close the lid ( the monitor ) to soon before the shutdown is complete; is the problem. when i power on agian only the fans, cdrw/dvd-rom lights appear. it doesn't boot windows and there's no screen just black. and although i have taken my system to adecco, but $40 later and no help, i ended up resurrecting my laptop myself. i went back and they were rude about it. PLEASE can someone help???? when i spoke w/Gateway they told me it's the motherboard and $600 to fix, plus $200 for the diognostics alone. i really don't think this is the problem? but don't know???? i keep my system up to date and make a point to take care of it.
  • 56 Answers
The problem is the power off sensor ... this is a sensor to shut the monitor of if u close the lid (monitor) so it seems like that this sensor is still on the closed status so try to find it then see if it's a mechanical try to move it with your hand and if it's an electrical try to but a light on it .... if it work please rate me!
Posted on Jul 31, 2007
SOURCE:
My Toshiba Satellite S75D-A7272 laptop has always had a problem with getting it out of sleep mode. Is there a fix for this?
Sleep or standby mode should allow your computer to conserve energy yet respond quickly to power back on when you need it. Most Toshiba laptops should exit sleep mode if you press a key on the keyboard or use the trackpad mouse. If the lid was closed, opening it should also wake up the computer. If none of these methods work to bring the computer out of sleep mode, you may have a power issue or software glitch. Causes Insufficient power can cause this problem, so try plugging in your Toshiba laptop before attempting to wake it from sleep mode. If this does not immediately fix the issue, your problem is more likely a software issue. If your laptop was shut down incorrectly prior to the sleep mode incident, it may be stuck on a blank screen that makes it appear to be in sleep mode when it actually is trying to start up.
Indications Press the power button for a few seconds to see if your computer will wake up. If it does, the laptop was not truly stuck in sleep mode, but rather went into hibernation mode. If your laptop is truly stuck in sleep mode, you may be able to force a shutdown by holding down the power button, but when you power back up it will move right back into sleep mode. In some cases, the power button may not shut down the computer from this mode at all.
Solution The best way to solve your Toshiba's problem is to completely remove all power from the laptop to ensure a fresh restart. Close the laptop's lid, turn over the unit and remove the battery. Also remove the power adapter cord from both the laptop and the wall socket. Open the laptop lid and press and hold the power button for approximately 20 seconds. This will drain any stored power in the backup battery. Wait a few seconds, then put the battery back in, plug in the laptop and press the power button to turn on the computer. It may start up with an error screen; in this case, select the option to start your computer normally. If the error recurs, start the computer in "Safe Mode" to see if a program running on your computer outside of the basic Windows operating system is causing the problem.
Further Help Sometimes this issue also requires holding down a specific key, such as "F8," when you restart. If the basic power drain and restart process doesn't work, you can use Toshiba's support website to look up further information for your specific model. Just click the "Product support" tab and enter your laptop's model information, then read through the support bulletins listed for your particular Toshiba model. Toshiba also maintains a support hotline at Call us : +1 850-610-1013 https://www.instantprintersupport.com/toshiba-printer-support
May 28, 2018 | Toshiba Computers & Internet
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
en.community.dell.com/support-forums/laptop/f/3518/t/19496556
Dell
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from en.community.dell.com
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
I cant enter sleep mode on my acer aspire one zg5. How do i fix?
Your settings in power mode have changed. Open up display and go to the screen saver tab (win 7) you will see the power savings option at the bottom. Go into that and change what the buttons do. You will have 3 situations to change. What happens when i close the lid, power button and sleep mode. Chances are you gave everything set to do nothing
Nov 22, 2015 | Acer Computers & Internet
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
Cannot get my Toshiba L505 Laptop out of Hibernation mode
you may find this helpful try it soon and let me know if it works
click here
May 16, 2012 | Toshiba Satellite L505-S5966 Notebook
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
May 02, 2012 | Sony Computers & Internet
I was using laptop, closed the top to put to sleep, on opening up back the laptop i disconnected power supoly for is was plugged in and then my computer shut off, it seems the battery is not responding...
sleep mode if all the hardware is still on, not what to perpergian sebantar pake sleep mode, for a long time you turn off / Shutdown. You can also laptops batterynya already can not store electricity. you try to charge back or replace a new Battery
Jul 27, 2011 | Acer Computers & Internet
Screen goes black when turned down and it does
try removing suspend on lid close .. refer to your laptop manual .. try this too disable herbernation also ..if nothing works check if you have latest graphic driver !! it might be a problem with ACPI .. but my two solutions should work !!!
Mar 10, 2010 | ASUS W7S-3P100E T7500 PC Desktop
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
Gateway (2500068) Motherboard Logo
127 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
