Question about iLO (2 GB) MP3 Player
How to remove write protect to usb
When i want to copy my files to my pendrive it shows an error dialoge box saying that it was write protected
  • 488 Answers
Your pendrive might have a tiny switch on its side that you need to slide to prevent the error message from coming.hope it helps!
Posted on Oct 30, 2008
My 8GB kingston pendrive is showing write protected and couldn't format or copy files on to it...
i have my 8 GB Kingston pendrive i have formated it. But afterwords when i am going to copy some data ie photos and film it shows write protected, so how can remove this write protected from the same.
Aug 30, 2011 | Fuji (MAP3367NP) 36.7 GB Hard Drive
When ever i try to copy a file on to my pendrive ,a file pops up saying that it is a write protected drive .how am i to remove this write protection?
try this one, hope it will work on your memory stick coz i tried this and i was able to format my write protected memory stick smile.gif
use a computer with XP OS.
right click 'my computer'
select 'manage'
then select 'disk management' to format ur memory stick. but sad to say, all data will be lost, am pretty sure you know it
Jun 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protection of my pendrive ? I cannot copy any files into it nor i can delete files from it.
Your pendrive has Virus.Format all the data and then try copying or try removng the Virus through a Antivirus..
Mar 25, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Jan 27, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Nov 07, 2008 | Transcend (589307) Media
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
Pendrive Problem
there is a small slide switch turn this off and see, if not then the pendrive is probably corrupted
Sep 17, 2008 | Buffalo Technology 250GB USB SATA 2.0 HD...
Write protection error on pendrive
Look for a small/tiny white switch on either the bottom or side of your pendrive and switch to the other side. there should be a tiny white switch on your pendrive...
Hope this help. dnt 4get to rate pls
Apr 09, 2008 | Computers & Internet
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
