Question about Sony SDM-HS73P 17" LCD Monitor
Constant white screen
Monitor used to work fine. Disconnected from tower, and reconnected later to another similar working box (which had a good working monitor already) and just got blank white screen. Screen flashes from black to white at post and operating system start up then stays white. Colors never appear and the Windows logo is never seen nor anything for that matter. Screen just stays at solid white after that. Cables seem to be good, and power light is green. Help! Thanks!
  • fpjuniorjd Sep 15, 2008
    My SDM-HS73 has been working fine for 4 1/2 years. Now, in the last 3 or 4 months, the screen just goes white. It happened a few times and I turned it on and off and it worked. Now, it lasts for a day or two and then it works again. Any input would be appreciated...Thank you..Frank
  • JTTX Oct 05, 2008
    I have a solid white screen that does not respond to any of the monitor controls ....it blinks once in while...totally unresponsive ...
  • 983 Answers
Check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Posted on Feb 06, 2008
SOURCE:
Why does my monitor start as white when I turn it on? THe mouse pad does not work as well.
Monitor cable disconnected internally?
follow http://www.insidemylaptop.com/replace-screen-on-dell-latitude-e5420-laptop/
and disconnect, clean and reconnect ALL monitor related cables. (You may need a new screen if that fails)
You may check your laptop by connecting an external monitor first.
Aug 21, 2014 | Dell LATITUDE Computers & Internet
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
Only says cable disconnected on screen
May be your monitor cable has been faulty.You can check it from service center.
Mar 24, 2010 | Dell E551 15" CRT Monitor
Monitor stays white, cannot get picture
U might have problem with ur VGA cable. It may be loosely plugged. Plug it tight
Jun 24, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Background noise from webcam
I had a similar situation. I have another capture card installed on my computer. I disabled the onboard device through Device Manager and then downloaded and installed the Newest version of the lifecam software, ver. 2.04, and then restarted the system. I also connected a microphone and used that rather than the mic built into the camera. So far, the loud white noise has not returned.
Good luck. I hope this helps and please let me know how it works out.
Feb 07, 2009 | Microsoft LifeCam VX-3000 Web Camera
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Open Questions:
Sony SDM-HS73P 17" LCD Monitor Logo
2,198 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
