Question about RCA LCDX2620W 26 in. HDTV-Ready Television
RCA LCDX 2620W 26" LCD
Please, i have a 6 inches vertical band on the left side of the lcd, is a yellow contrast, somenthing is wrong with the lcd or the components??, thanks!
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
  • 7 Answers
SOURCE: RCA LCD TV INVERTER BOARD
I have a new power/inverter board for a L32HD32D RCA 32" flat screen LCD TV. Make offer, 1-907-225-2337 I'll ship it USPS in the box it came in.
LS2HD32 CEG379B CAJAID, CAJA4465 1114363 are some numbers on the package it came in. You might try LPS#1 on the ribbon cables & their video board connection for the LCD by opening the back 4x5" pannel in the middle & clean reinstall them ? That's what fixed my TV, maybe. So I don't need the board now. It's only about a 5 minute job to clean the 2 ribbon cables.
Sincerely Bitdog
Posted on Feb 16, 2010
SOURCE: Problem for RCA L32HD35D 31.5 inch HDTV LCD TV
With a bright flashlight see if you can see a picture.. If you can this indicates your invertor board has failed. If not more than likely your main video board has failed. Ebay has tons of parts for these tv's.
Posted on Apr 03, 2010
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
  • 15 Answers
SOURCE: RCA LCD TV 26 screen turns white, no sound no nothing
You have a blown fuse in the power supply. It does not look like a fuse.
It is near the top of the board and is labeled as 1.6 amp. It supplies 12
volts to the main board (via q422). A 2 amp fuse should be a fine
replacement.
Posted on Nov 18, 2010
I have vertical black lines in my Samsung s42ax-yb09 plasma TV. one 3 inch band down the right side and a 9 inch band down the middle a foot from the right of the screen and 15.5 inches from the left
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 29, 2016 | Samsung Televison & Video
Picture ok with a 6 inches blue vertical line from top to botton
For a five or 7 inch band we have a fix. Six is a big problem. A vertical band is either a sync condition requiring an adjustment of one or more pots on the circuit board. Usually the condition is Horizontal and rarely up and down the screen. LED is generally very reliable and two of 3 colors within the diode in your case (one red and one green) are not working. If this TV is in Warranty, replace it as you cannot fix this yourself.
Jan 10, 2014 | Samsung UN55EH6000 55" Class LED HDTV...
My RCA L42FHD37YXII has dark green and light gray vertical stripes on left side of tv it is on all connections
the screen might be broken. when that happened to one of mine i found a crack on the edge of the screen in the glass/plastic? type stuff but it only affected the aria right near the crack. found out my roommate chucked his glasses at it. if not idk
Sep 30, 2012 | RCA L42FHD37 42 in. LCD HDTV
I have a thin yellow line running from top to bottom about 10 inches from the left side, what's wrong?
This can be due to faulty LCD driver IC which creates a noise bar and is shown. Check the cords to the display and also the ground connection to the display. If this is good then the IC can be faulty.
Dec 15, 2011 | Hanns.G Corporation JW-199DPB 19" LCD...
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have an 8 inch wide yellow vertical band in the picture of my 52 inch LCD Samsung TV, what is this? I just moved into my new house a couple of weeks ago and purchased a new 52 inch TV, We are without...
If the band is there within the menu then the screen has a fault. If not then possible signal ghosting issues and a proper aerial should fix that.
Jun 30, 2017 | Televison & Video
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
RCA LCDX2620W 26 in. HDTV-Ready Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
