Question about Frigidaire GLTF2940ES Front Load Washer
No spin E20 alert on washer - Frigidaire GLTF2940ES Front Load Washer
Clean out filter (small door front bottom right, then unscrew filter and clean it)
Posted on Jan 24, 2009
Repeating E20 alert on washer
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you!!
Jun 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
E20 message want spin
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
My washer will not spin and posts E20 error
E20 means that there is a clog somewhere in the drain line. Check the hose, check the check valve at the pump, make sure nothing is clogged or stuck. It should not take you that long to find the problem.
Aug 23, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Mar 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
No spin E20 alert on washer how can i fix?
E20 is saying that the water is not draining, locate and clean filter if washer has one, check pump and outlet hose for possible blockage, make sure drain hose is not trapped or restricted in any way.
Plz rate my solution.
Thanks.
Jan 21, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
E20 ERROR
It doesn't spin because it has to drain first. E20 means not draining. You'll very likely have something caught in your drain pump. If you take the two screw off at the front, very bottom of you washer you'll be able to pull down the small panel to reveal the drain pump at the right corner. if you empty all the water from your machine you can take off the spring clamp attaching the thick rubber hose from your tub to your drain pump. ( you may want to have some old towels ready ) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Sep 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
My washer wont spin out it has a code that is E20
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 12, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
