Question about Bosch Dishwashers
Our bosch dishwasher is not working, when we press the button to turn on nothing happens, no lights, nothing, we have checked the fuse and thats ok. many thanks gail
You may have to turn off power at main box, and check wires at bottom of machine and any other junction box , from dishwasher to main power box. pull on wires to see if they will come apart.
Posted on Oct 30, 2008
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
Aug 30, 2016 | Bosch Dishwashers
Bosch Dishwasher won't fill with water
Certainly *sounds* like the float is stuck in the over filled position
or possible a bad float switch, if the float is stuck in the up or full position, the d/w will not fill with water and the drain motor will often run all the time
Jan 23, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a dishwasher bosch model SHE3AR55UC/07. I press the ON button to turn dishwasher on. And when I press START button, the dishwasher does not start.
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Aug 27, 2016 | Bosch Dishwashers
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
My dishwasher will not start. The 3 second button light is on and when I press it nothing happens . I try pressing any other button and nothing works
It sounds like you have "locked" the dishwasher. This was an added feature that most people never wanted since it only seems to be set by accident.
Try pressing the 3 second button and holding it down for at least three seconds. This should turn the light off. Drove us nuts the first time it happened. If it doesn't turn off then I guess it is broken.
Jan 03, 2010 | Maytag MDB7100AWB Dishwasher
Dishwasher stopped. no lights, no nothing
My Kenmore just did the same thing, I verified power to the unit.
Jun 26, 2009 | Bosch SHU3306UC Built-in Dishwasher
My dishwasher just stop, the red light come on and nothing happen
check the filtrs in the machine are clear and the waste pipe is not blockedput it on rinse cycle and see if it empties
Jan 26, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch Dishwasher doesn't run
double check power to your plug socket ( use bedside lamp)
check fuse in plug
check water supply ( run the water supply directly into pot/bucket)
make sure door closes properly (if built in )
if built in remove and then check!
Feb 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
226 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
