Question about Frigidaire ATF6000ES Front Load Washer
Kenmore/frigidaire motor model # J52AAC-0102 has noisy bearings
Is it possible to replace the bearings on this motor?
  • Greenlojo Jan 02, 2009
    Not sure if the problem is in my bearings or not... when the rotor spins in the stator, I hear a dull 'rubbery' noise. I would like to find a replacement motor in case I completely hose it when I take it apart.
    Problem Solver:
  • 3 Answers
Yes you can, I replaced mine with a NTN6202 grainger no.6L024
6202 LLBC3/L627 works for me.
Posted on Oct 27, 2010
NOISY KENMORE ELITE DRYER
what's the model number,kenmore doesn't make anything,if it starts with 110. it will be whirlpool made,if it's 417. it's frigidaire,if it's a whirlpool it will be a belt kit,you get the belt,rollers and pulley,if it's frigidaire made most likely it will be the rear bearing.
Feb 12, 2014 | Kenmore Dryers
My Kenmore Progressive Whisper Belt canister vacuum is not "whispering." In fact, it makes excessive noise during operation - much more than the older Kenmore model that it replaced. I have replaced the...
Probably either bearings in the roller brush, a damaged fan blade, or the bearings in the motor. Take the roller brush off completely, and run the VAC without it. If it's much more silent, then the problem is with the bearings in the roller brush. If it's still noisy, then look closely at the fan that produces the suction, if you can. If you see any damaged blades, then you'll have to replace it. If it seems fine, then it's most likely bearings in the main motor that will have to be replaced. The bearings and the fan blade are NOT expensive parts, but the labor at a shop to change the main bearings would be kinda pricey.
Oct 18, 2013 | Kenmore Vacuums
How do I fix my Kenmore front load washer ?
your drum bearings have gotten water in them due to a bad lip seal on the back side of the inner drum,if you can buy the bearings and lipseal you can tear it down and replace these rusty noisy bearings,and leaking seal
Aug 26, 2012 | Washing Machines
Noisy motor on model 64810
Possible failure of the bearings of the motor
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 12, 2012 | Washing Machines
Kenmore 16532 dishwasher,three years old. It has slowly gotten very noisy. I have stripped down everything I can access from the tub, including the chopper. I can't find any problem. It is quiet while the...
It could be 2 things:
a) water obstruction in the spray jet ports causing uneven rotation of the spray arm.
This uneven rotation will eventually wear out the motor bearings.
Fix: clear out any clogged spray jet ports.
b) the motor bearing are already shot, and they're growling and howling in pain as the motor grinds them to death.
Fix: replace motor - new bearings will come with the new motor.
Alternate Fix: replace dishwasher. Often new motors are so expensive, replacing the whole unit is the bast option, especially with Sears/Kenmore (where parts are expensive)
Try: www.SearsPartsDirect.com.
I tried the sears parts web site for you, but you model number came back to a Bissel carpet cleaner.
Oct 15, 2010 | Kenmore 24 in. 16532 - Multiple Color...
Kenmore Elite model 665.15932 motor is now very
1)check any jam on impeller(motor)
2)check whether bearing plm.(possible replace the bearing)
Mar 01, 2010 | Kenmore Dishwashers
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
Drain light is flashing
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30.
Thanks
Oct 20, 2009 | Kenmore 73952 Gas Dryer
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
445 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
