Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Igniters won't stop poppong
Have dual fuel oven w/gas burners. Cleaning the cook top, with wet rag, got sparks, and igniter will not stop attempting to ignite burners. Turned off power-same prob. when breaker turned back on. Now it is unplugged. Any suggestions? Any reset button, etc.? Thx.
  • Anonymous Mar 15, 2014
    our gas cook top has stopped igniting
    President:
  • 878 Answers
Sing, sounds like you got one of your burner valve switches wet and it's grounding out. Try taking a hair dryer, pull of the burner knobs and going lightly over the control valves. The switches are mounted to these valves. It just may need to be dried out. If this doesn't work, one of the switches shorted out. Catriver..post back.
Posted on Sep 11, 2006
One or more igniters are trying to light burners that aren't turned on .One burner is on. The other post on this never got answered properly.
When you turn the burner dial, all igniters spark. Most brands work this way. The dial activates all igniters to spark but only opens the gas valve attached to that dial.
Do you mean that they continue to spark even when you are not trying to light the stove?
Jul 28, 2009 | Jenn-Air JJW8530C Expressions Collection...
Bad ignitor needs replacement
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
Oct 23, 2017 | Jenn-Air JGC9430ADS Gas Cooktop
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
All igniters sparking
the only thing which I found is after I clean the burners, maybe some dirt in.
Jul 06, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Ingiters don't work - all burners
Unplug cook top. remove drip pan with screwdriver. Use hair dryer to completely dry area that might have gotten wet during cleaning. This may take five minutes. Put unit back together and plug in cook top.
Apr 27, 2008 | GE 30 in. JGP337 Gas Cooktop
Had The same problem. I removed the top of the control panel to find out that one of the ignitor switches had turned when I replaced the four large plasic nuts on the control panel. Make sure the switches (block) are aligned, and kept aligned, when re-installing the top of the control panel. Startwreck.
Jul 15, 2007 | KitchenAid KGST307 Gas Kitchen Range
Igniters won't stop when pan on high output burner on high
This is caused by the ignitor not sencing the flame or the burner requires cleaning. Regards Engineer
Apr 18, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Igniters don't ignite
I would try cleaning them first. Generally, they should be cleaned periodically. If this does not work then check the igniter.
Feb 09, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
507 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
