Keurig B60 Coffee Maker
Problem for Keurig B60 Coffee Maker
Keurig problem.
By wgranger on Oct 30, 2008
I have had and used this unit for almost (2) years now without problem. Today, when making a pot of coffee, the unit did not disperse into the cop however inside the unit somewhere and on to the counter top.
If this unit is plugged up, is it normal to dispense to the inside of the maker and to the counter top? Please provide a repair recommendation as well as provided if needed.
Thanks.
Same Problem
Jan 17, 2009
-   I HAD THE SAME PROBLEM AND KEIRUG TOLD ME THE HOSE CAME OFF AND THE COST OF REPAIR WOULD BE COSTLY; IT WOULD BE CHEAPER TO BUY A NEW ONE... I HAVE A B 60 AND HAVE HAD IT FOR 3 YEARS.... I DID PURCHASE A NEW ONE FROM KEIRUG BECAUSE I LOVE THE MACHINE.. MEMA15 -   Guest
Solution #1
posted on Feb 14, 2009
Not Rated)
RuPrayn2
Rank: Apprentice
Rating: 85%, 1 votes
We have just had this problem to happen to us, when my husband unscrewed the screws in the bottom of the unit, he found that the HOSE had shaken loose or came off. Inside was a small plastic tubing that connects together to let the water run from the reservior to the drip chamber. Once he reconnected the water hose everything worked properly. I pray that this helps you!
Was this helpful?
Yes
No
Solution #2
posted on Nov 21, 2008
Not Rated)
gadgetlady2
Rank: Apprentice
Rating: 0%, 0 votes
Check to see if the gasket around the top "pointy thing" is damaged or missing. That just happened to mine.
Keurig will send you a replacement gasket free of charge. Just call them at 1-866-901-BREW (2739) with your model and serial numbers. The numbers are on the bottom of the machine.
Was this helpful?
Yes
No
Solution #3
posted on Nov 01, 2008
Not Rated)
mrsadams
Rank: Apprentice
Rating: 78%, 2 votes
We had a pot for almost 2 years and loved it, then it started making coffee all by itself. We had purchased it at Costco, so they took it back as defective. We are now on our 5th B66 pot in the past few weeks. I have worked with Keurig on 3 of these pots and they finally sent me a new one from the factory. We used it for 2 days and now have the same problem. The other 4 just kept saying Not Ready. After talking to several tech's at Keurig, they think the heating elements are burning out in them. They could be a fire hazard, so be careful. We are contacting the Consumer product Safety Commission. I loved my pot and really miss having my coffee. I would call Keurig and report the problem. Maybe they can tell you how to replace the heating element.
Was this helpful?
Yes
No
Popular Solutions for Keurig B60 Coffee Maker
Questions and Unsolved Problems for Keurig B60 Coffee Maker
Do you recommend Keurig B60 Coffee Maker?
Answer
Answer
the water doesn't come out through the needle- it seems clogged or disconnected and the water comes... (More)
Answer
The machine does not always dispense the correct amount of water
Answer
pump doesn't work; can't find a soruce for replacement
Answer
It will not brew at the programmed time.
Answer
It starts to brew, then only dispenses a little amount of coffee. I have checked the exit needle and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Keurig B60 Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2520
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
