Black screen with only mouse pointer
When i turn on the computer there's only black screen and mouse pointer.
what do i do?
Well try to start pc in safe mode you can do this by pressing F8 key at windows startup after this remove your display(VGA) driver from device manager and then try to start window normaly if its start normaly then you have problem with your VGA.
And if its does not work then try to reinstall your windows
some times Asus and Msi motherboards have this problem,do nt know wthats is yours
hope you have got answer
regards,
Ali
Posted on Oct 30, 2008
Want to make my computer pointer black and larger so i can see it better how do i do this?
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
click on the >> or the control panel for xp
navigate to the mouse select the pointers tab you will see a browse option where you can change the mouse pointer to black
W7
hope this helps
Jul 11, 2012 | Dell Inspiron iM50302792B3D Notebook
How do you unlock mouse on Laptop Toshiba? It is locked in the middle of screen.
is your mouse a lead or wireless mouse??? make sure the lead is securely seated make sure batteries are charged and the usb device is insereted correctly
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer if your mouse works in safe mode
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
or
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Sep 13, 2011 | Toshiba Computers & Internet
Help! My Dell Inspiron Desktop (Windows 7) went into sleep mode, I shook the mouse to use it and got a black screen with just the mouse pointer. I powered down & back up, got the Dell screen and the...
My guide might help you, it's worth a try, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Sounds like a windows error though, some how the installation may have been corrupted. I suggest performing a virus scan on a test PC. An alternative is to take it in to a computer technician.
Thanking you
Happy testing
damnor01
Nov 15, 2010 | Computers & Internet
Pointer Mouse froze in the middle of the screen Please help i cant get it to move so i cant use the Computer Thank you Very Much . Bill
if there is a light above the touchpad it should be blue if it is orange it is turned off push the button by the light it will go blue and the mouse will work.
Jun 14, 2010 | Toshiba Satellite M35X-S161 Notebook
Black display after vista splash scrren
You may have an infection.
Anyways...this is what you should do to regain control.
When you get to the black screen and the mouse pointer, press Ctrl+Alt+Del
The next screen will ask you what do you want to do...
Select Task Management....(one of the last if not the last option)
You'll get the Task Manager Windows.
Go to the Processes tab
On the File menu choose New Task (Run), and type: explorer.exe
Wait a little bit, and your desktop should come up.
Once there, run an antivirus antyspyware, anti adware etc, to get rid of the problem.
Once you KNOW you're clean and back in track, I recommend you to look into www.labellpcsolutions.com.
They have a product called Pc Guard, that protect your computer from all this problems effectively.
Please don't forget to rate this answer if helps.
Jul 02, 2009 | Compaq Presario 700 470024-192 Notebook
Black screen with mouse pointer after lcd screen repair
If you can see a mouse pointer clearly, you have a software issue especally if see a post..
Apr 20, 2009 | Dell Inspiron 1525 Notebook
Black screen mouse pointer visible after i enter my password
hi..this problem is due to the loading drivers
during the time of login.The reason for the problem
may be due to the following reason.some files could
have got corrupted while loading drivers that may be
some damage due to the windows file corruption or
due to the virus corruption.
try it out..
thank u..
Feb 05, 2009 | HP Pavilion dv4000 Notebook
Black sceen with mouse pointer on it after start up
Try replacing RAM modules, if that does not work, then replace the motehrboard.
Jan 09, 2009 | Acer Aspire 5315 Notebook
Black screen with mouse pointer and taskbar
Had the same problem with a friend of mine. Turned out to be MalWare interfering with security accessibility. Had to re-install windows. But id you have a restore point I would try that.
don
Sep 30, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
1,200 people viewed this question
David Payne
David Payne
