Question about RCA 27V530T 27" TV
No color The TV when turned on one day suddenly was without color. It has a good black & white picture. The color did not gradually go away, it just wasn't there. The tv is only about 3 years old. Please recommend what can be the problem and hopefully repair it at home. On some of the websites I visited it referred to the Chroma chip/circuit loose or maybe bad. Please describe what this part looks like so I can investigate it. If you have a schematic for this model that would be helpful. Thanks Diane Peel
  • Bryan B Jan 05, 2008
    I was watching TV and my color went out I have a good clear black and white picture no color how do I fix it thanks Bryan
  • robbonm Mar 06, 2009
    Same problem, all of a sudden no color but good B&W pic. DVD plays movies in color, but all channels in B&W only. Not a Directv problem, as they were out today.
Replace 3.58 crytal in coroma section
Posted on Feb 04, 2007
It is probably wise to seek help from qualified technician to fix your tv sets otherwise you will just end up regretting because you will just make its defect worse.
Posted on Feb 06, 2007
    Scholar:
  • 168 Answers
A trouble in any of the following circuits may cause the symptom: bandpass amplifier, ACC, color killer, 3.58 Mhz oscillator, 3.58 Mhz output, burst gate and burst amplifier. but as techman told you, if you are not inclined in this kind of job, better bring it to a qualified tv technician.
    President:
  • 3,130 Answers
Diane, so sorry to burst your bubble doll but this is not a place for you to even consider experimenting with. Do you know how to read a schematic? Do you know what a burst amp is or how its generated? Really you should not attempt to repair a TV set unless you understand how the color or how the other circuits work. Do you know how the croma Oscilator and the burst circuit works together in the video to produce color? Please unless you can answer all of the abouve , seek out a pro to assist you in this repair as I said many times before, a solid state TV set has no user serviceable parts inside them.
Posted on Sep 11, 2006
Poor viewing quality
By poor color quality, do you mean that if you turn the color control all the way down, the black and white picture is more like black and red, green or blue - or do you have a good black and white image? If the B&W image is good, and the TV is an old (8+ years) one, maybe the mirror inside the set needs a good cleaning - especially if there are smokers in the room. If you have a B&W picture that is tinted, then you may have to go into a service menu to adjust it back to a better picture. Hard to guess the problem without more specific description of symptoms.
Jul 17, 2012 | JVC HD-56G787 Television
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
My samsung dlp 6163 display suddenly changed to B&W
Bad Color Wheel!!!!! Call Encompass for Part 1-800-638-3328 if out of stock call Mats 1-800-628-1118 Just looked it up encompass is out of them right now part # BP96-00674A Listed for 129.69 Go to E-Bay Lots of good deals for TV parts. E-Bay has 4 prices range from 122.00- $149.00
Sep 29, 2009 | Samsung HLP6163W 61" Rear Projection...
Having problem with getting the color and contrast right?
Good Day;
Turn your color down all the way, do you get a good Black and White picture with good black, white and grays? If not your picture tube may be going bad. It can be adjusted sometimes to get a 'better' picture.
If picture is a good B&W; adjust britness level: 50% > contast: > 90/95 % >color: 50%.
Good Luck, big IRISH.
Sep 25, 2008 | Televison & Video
T.v
The first thing you need to do is to take away the color completely, then you adjust the hue until you get the picture looking like a black & white tv, like the old shows that were broadcast in black & white.
Then you can gradually add the color. And thats it your done!
Jul 19, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Feb 05, 2008 | Televison & Video
No color
If the settings are correct and the signal is good but there is no color, it can only be one of 2 things - the CXA jungle IC and the chroma crystal next to it. If you have never replaced small parts on PC boards then have a qualified tech handle it for you.
Aug 09, 2007 | Sony KV-35S45 35" TV
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Dec 02, 2006 | Panasonic PT-47WX42 47" Rear Projection...
RCA 27V530T 27" TV Logo
472 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
