Question about Home
Bath rail Can you please let me know how to fix my Bath rail. It not working after bleeding the radiator. Is there a problem with the valave?
  • James Feragola
    James Feragola May 11, 2010
    What model is the bath rail?
    As much info as you can give me.
    Feragola
This is now working o.k
Posted on Dec 02, 2008
Where is the a/c expansion valve located on 2006 range rovrer
1 - Radiator
2 - Thermostat housing
3 - Radiator bottom hose
4 - Viscous fan
5 - Water pump
6 - Radiator top hose
7 - Heater return hose
8 - Coolant supply hose
9 - By-pass hose
10 - Radiator bleed (purge) hose
11 - Bleed (purge) hose, thermostat housing
12 - 'Y' piece ejector
13 - Expansion tank
14 - Heater rail
15 - Heater unit
16 - Heater feed hose
17 - Intercooler
18 - Air cleaner
19 - Air feed hose
20 - Turbocharger
21 - Charge air supply hose
22 - Cooled charge air supply hose
23 - Exhaust manifold
24 - Engine oil cooler
25 - Feed pipe, engine oil cooler
26 - Return pipe, engine oil cooler
27 - Oil filter
Aug 22, 2016 | 2006 Land Rover Range Rover
I need help locating the radiator cap
That kind of car has a surge tank style cooling system. Adding water to it to fill the radiator is correct. Do it while it's running. To bleed the system, near where the upper radiator hose goes to the engine, you'll see a little nipple. Loosen the nipple with an 8mm wrench or socket. That's your cooling system air bleed. When you have a steady flow out of it, close it.
Jan 22, 2014 | 2001 Chrysler Concorde
All radiators cold
you need to re bleed the system. starting at the end radiator. one furthest away from the boiler. and work your way back. re filling the system put air in to the system and you need to get it out. pressure should also be a 1.5 to 3 bars for a good flow in the system. also make sure all the flow taps are open when doing this bleeding or you can trap air in the line.
Jan 19, 2014 | Cars & Trucks
My Pontiac Sunbird 96 ran out of fuel. I need to know how to bleed the system of air. Where is the bleeding line??
you shouldn't need to bleed the air out-if you filled back up with fuel and its not starting you probably have a bad fuel pump-sorry- to bleed the fuel line look where the fuel line connects to the fuel injector rail-on the rail there should be a thing that looks like a tire inflator valve-turn the key on and push in the center of the valve and fuel should come out of it -if not then for sure pump isn't working- cheers Denny
Nov 27, 2013 | Cars & Trucks
Gas in oil, flooding, no power
Don't run engine. Loss of power can be from washed out cylinders from gas bath. Friction also increases and engine will seize.
Check fuel pressure at fuel rail for excess pressure. Dirty injectors can fail to close. They put a pressure gauge on system and then check for a bleed down.
You can borrow some tools from big autoparts chains.
Drain oil and change filter. Temperature controls on engine can fail and keep engine too rich.
Jan 05, 2013 | 2001 Chrysler Voyager
I have just refilled by hot tub with a balboa 500z pump. After refilling it the pump is working fine but the jets are not. The dr light has come up. Please can someone help me bleed the pump to get it...
Priming can be done many different ways depending on thetubs design. Some tub manufactures provide bleed valves located on the plumbingjust beyond the pump and heater unions. Some pumps have a bleed valve locatedon the pump. If there are no bleed valves then you will have to release theunion nuts to allow the air to escape.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Hope that helps.
Jun 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
Hi, i have a problem with a 2002 BMW 323i the problem that i had is that the car overheats after 20-30 minutes drive, i already change my fanclutch, fan blades, wather pump, thermostat and temperature...
I can think of a few other things to check. Are you sure the radiator is not clogged and just needs cleaning out? Are the fins on the radiator bent close preventing air from flowing through the radiator? Is there a bleed screw somewhere on the engine cooling system that you are overlooking. If so, bleeding it the old fashioned way as you did will not work. You must use the bleed screw. In addition, are you positive you do not have a blown head gasket? Symptoms are overheating, loss of coolant with no apparent leak, white smoke from the exhaust, a white foamy substance on the underside of the oil fill cap, oil level overfull, and air bubbles escaping from the radiator with engine running, radiator cap off. I hope you do not have a blown gasket and wish you the best of luck finding the culprit. Merry Christmas.
Dec 24, 2010 | BMW 323 Cars & Trucks
Cant find the thermastat in the radiator
U really can't find it there! It suppose to be in the engine! Follow the UPPER radiator HOSE from the radiator to the engine, there would be a CAP w/ 2 or bolts holding the cap, open it and u could see the missing"THERMASTAT VALAVE"!
Nice to help somebody!
Nov 20, 2010 | 1994 Mazda MX-6
John Deere 310 A Hydralic problems
Jd 310 A, boom down to dig then back off stick alittle and circut loses power.
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Home Logo
185 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
