you will need to order the z6100ps hard drive and not the hpgl hard drive you may want to try re writing the eeprom using the diagnostics mode 9 from mainPCA to HDD although I'm fairly certain it will error out as its the wrong type of hard drive
Windows 7 is a pain with large external hard drives you might get messages saying the hard drive needs to be checked or formatted do you want to check the disk now or do you want to format it now.
When there is nothing wrong with it at all.
External hard drives can be used on most computers and operating systems with minimal or no requirements other than leads and drivers.
If you are thinking of changing your hard drive for a bigger one it becomes a little more difficult.
However if you want to just remove it and put it back, its easy. On one end of your PS3 there will be a small cover which is prised out. Under that is a little blue screw. Take this screw out and there is a little metal pull out clip that is attached to the side casing of your hard drive. Pull the clip backwards and your hard drive will slide back. You can then remove it from the PS3.
Hello my friend, regarding on your problem the contents of your hard-drive is safe no need to worry cause the data is still there. Unless the hard-drive itself is corrupted that's the time your data will lost. To make it safe, you can retrieve the content of your hard-drive either if you have tools and skills in fixing hard-disk then youn open it and manually attach the hard-drive to your computer using the appropriate conector you have or you can find a technician in your place to fix and scan your hard-drive and to help you evaluate the main reason of your problem and also to save the contents of your hard-drive.
Hope this information helps you if you need more assistance then just post some reply in here.
Hello. If the hard drive will not reformat inside the PS3 when you press X, then you will need to remove it and reformat it on a PC using an external device or replace the hard drive. Thanks.
this problem is made loss connection of the hard drive, Busted battery In the motherboard, Is this new harddrive? if yes then check the jumper setting, see label setting on the hard drive. It should be the hard drive is the master. no problem with your CD rom.
solution: replace the battery in the motherboard. and fix loss connection of the hard drive. or refix all the connection inside the system.
same issue occur, try to examine the hard drive maybe maybe you have to interchange the connection of the hard drive and the CD rom. if still , then try to not connect the CD rom only the hard drive.
Failure to resolve in this solution you may either change the cable of the hard drive or change the hard drive.
