One moment it's working fine the screan is blank but I can get program information but no pictureOne moment it's working fine the screan is blank but I can get program information but no picture
You can't post conmments that contain an email address.
If you are a dish network subscriber, my suggestion will be to call technical support to help you. If you're using atmega or any other type of decoding devices then there is an ECM to test some of the nagravision3 encryption that might take effect some time soon.
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
? 2:07
https://www.youtube.com/watch?v=Tk7EUAEncsQ
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
May 24, 2012 - 7 posts - 5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Do you have frequencies programmed into the other channels? Use the MANUAL key to advance through the channels. If each shows a frequency of 000.0000, you need to program the scanner. It will automatically show LOCKOUT for each unprogrammed (000.0000) channel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Thanks.
check your unit if it is cable tv compatible.then, hook your cable to antenna in.then do the manual tunig/search for channel.if not,you'll need to buy a cable converter ,much better if it has audio/video out.
try to reset ur tv to factory setting.....should be in ur instruction booklet...when done try to set to automatic channel search and it should find Chanel for ur area
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
