Question about Saeco Royal Cappuccino Espresso Machine
Saeco royal cappuccino coffee machine beans container empty fault
My coffee machine says beans empty when they are not
i can strip it down and clean it out and it goes for a while
i cant see any broken or loose wires
where is the hopper sensor located
or do you have another fix
  • 1,089 Answers
Hi
More than likely your grind is to fine. Push the lever back 1 # larger(Higher #). If you want stronger coffee, push the doser lever on the door to the back then pull forward 1 click.
Posted on Jun 01, 2009
My Saeco Royal coffee machine is displaying 'empty water container' and it is full - what is the problem
Is the floating magnet in the water reservoir floating ? If yes, you will have to check:
1) the micro switch which is located just beside the magnet (open the machine to check it with and ohm-meter) Check it with a small magnet that you have
2) if the micro-switch is OK with a hand-held magnet the floating magnet may be de-magnetized
3) if everything above is OK, the input on the control board is perhaps defective
Mar 23, 2012 | Saeco Royal Cappuccino Espresso Machine
Saeco Grinder problem
The machine possibly out of carbon lead, which is use for electrical contact to the machine.
Mar 02, 2008 | Saeco Royal Professional Espresso Machine
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
I have a Saeco Royal Cappuccino maker that is signalling "beans Empty" is making the grinding noisd but the beans are not actually entering the grinder
The grinding burrs need cleaning if we consider than nothing have damage them.
First and simple advice is to use the vacum cleaner and try to **** everything from the grinder and try again the machine. If the problem is insist then you need to sesasemble the grinder and clean the hole grinder with the vacum and also with a wire brush.
Good luck
Mar 23, 2010 | Coffee Makers & Espresso Machines
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Cappuccino Espresso Machine Logo
315 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
