Question about Xerox WorkCentre 470CX InkJet Printer
WorkCentre 470CX: When I press print, it gives me No Paper error when there is paper
The Printer won't take any paper even though there are many sheets of paper in the tray.
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
Dec 06, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
Can I use Work Centre 470cx with WIN 7?
You can downlad the vista driver from the xerox website and try but 470cx is not supported yet with windows 7 http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=470cx&ripId=&Xtype=download
Nov 21, 2009 | Xerox WorkCentre 470CX InkJet Printer
Can I use Xerox WorkCentre 470cx on a wireless home network?
You can get a parallel print server and configure that.These may be hard to find though.
Jul 22, 2009 | Xerox WorkCentre 470CX InkJet Printer
LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
What cable do i need to print from my workcentre 470cx to laptop?
You will need a parrallel cable that supports IEEE standard 1284 and is not longer than 12 feet.
You can consult the online user guide available by clicking here and go to page 1-8. If your laptop does not have a parrallel port you will need to purchase a usb to parrallel adapter cable like the one shown here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Xerox WorkCentre 470CX InkJet Printer
Printer thinks its out of paper
  1. Open the Document Feeder by placing your fingers under the opening where you feed paper, and lifting upwards.
  2. Locate the black Paper Sensor (the black plastic switch that hangs down).
  3. Make sure the Paper Sensor is not pressed in. It should move up and down freely.
  4. If the Paper Sensor is stuck in the up position, try to gently pull the Paper Sensor back down.
  5. Turn the power off by pressing the Power Switch to the [ O ] position.
  6. Turn the power back on by pressing the Power Switch to the [ | ] position.
  7. Try to make a copy using the Document Feeder.
  • If the Paper Sensor is broken off or pushed in, you will need service on your WorkCentre.
  • If the Paper Sensor is not broken off or pushed in, the Paper Sensor not the cause of the problem
Oct 02, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre 470CX InkJet Printer Logo
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
