Question about GE Energy Star WCVH6260F Front Load Washer
Not draining all the way
Pump runs but the water stays in then the door unlocks and locks and it trys to pump the water out again.
  • whipd Oct 30, 2008
    I've checked that and the tue was clear. Its like its not sucking it in.
    Problem Solver:
  • 5 Answers
Http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
  • 903 Answers
Try unblocking the outflow pipes to the machine. The pump may be trying to pump the water out but the pipe might be blocked with debris i.e. hair/fluff etc... Look under the sink and you will see the outflow pipe attached to the sump (or u-bend) with a bowl or pot handy (because of excess water), take the pipe off of the sump and check for blockages. Then if you can check the u-bend too and see if this help.
Posted on Oct 30, 2008
  • Debs
    Debs Oct 30, 2008
    It will probably be the pump then. Remove the panel under the door and again with something to catch excess water with (probably a lot), unscrew the filter and pull out, it will probably have loads of debris blocking the pump and causing your problem
Whirlpool wfc7500vw when put into any cycle selection the door lock lights comes and stays on and the draining/unlock light flashes for a minute then the door unlocks once opened and closed the cycle...
When you first start a load, the machine does perform several self checks. One of them is the door lock test. It locks the door and checks a loop back signal from the lock. At this point, it usually tests the drain pump to make sure it cycles on and off. In my case, the Maytag unit we own actually unlocks the door and immediately locks it again right before the actual wash cycle begins. I suppose this is a double check because if the door indicates it is unlocked, the washer won't do anything (like fill up with water, or spin...anything that either floods the room and hurts somebody). The door switch should be the impetus to start the tests. If the switch is mounted to an adjustable bracket, or the bracket is loose, then maybe it is being pushed out of position when you close the door. The fact that you can open the door after it unlocks, re-close it and the machine works normally tells me there is adjustment that needs to be made. Either the the little lever or pin that actuates the switch is bent or broken, or the door needs to be adjusted on its hinges to get the pin aligned correctly. Hope this helps. Keep us posted.
Kindest regards, Carl
Aug 15, 2014 | Washing Machines
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
Nd code and door locking
There could be another coin in the drain pump, jamming it.
With power disconnected..........Does the pump turn by hand in both directions?
Nov 21, 2017 | Maytag NFW7200TW Front Load Washer
Whirlpool front load washer model WFW9050XW00 - Machine stopped still loaded and with door locked. I was able to unlock and remove clothes leaving water and heavy suds. Tried running drain-spin and...
Your pump is jammed with a blockage, remove the filter and check the pump behind it is revolving, usually a hair grip or button in there...remember the washer is full of water so you will have a lot of water coming out
Sep 05, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Door lock will not release..will not work even with pushing the pause button
The usual reason the door will not unlock is because all the water has not drained from the washer...the door lock is tied together with the water level components and until the water level level switch is satisfied the wate r has drained,it will not allow the door to unlock. Typically the reason the water hasnt drained fully is because of a blockage in the filter on the pump.
This tip i wrote will tell ya how to clean that filter on the pump.
http://www.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Sep 05, 2011 | Kenmore Front Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
GE front load washer- error msg "door locked"
have you checked for any foreign objects in the drain pump itself this if the most likely problem.or the drain pump has completly stop.make sure you pull the drain hoses from the pump and check for foreign objects if there is still water in the unit use a shop vac and connect it to the drain hose to remove all the water before disconnecting the drain hoses. after the water is drain this may unlock the door as well
Sep 16, 2009 | GE WSXH208A Front Load Washer
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
Door locked light stays on so cannot open door
Make sure that all the water has drained or the door will not open, lay the hose into a bowl or other shallow vessel and let any remaining water run out. Wait a for a while for lock to release,if it still does not open then the door is going to have to be opened by force.
Plz rate this solution.
Thanks
Dec 16, 2008 | Hotpoint Aquarius WD63 Front Load...
GE Energy Star WCVH6260F Front Load Washer Logo
126 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
