Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Broken Pull String
The pull string/rope on my Dad's chainsaw broke. We rewound it but now it does not fully retract the rope after starting the chainsaw. Does the spring need to be pre-tensioned a couple of turns before attaching the rope?
  • 1 more comment
  • kellybanner Feb 10, 2009
    my problem is simmiliar cannot figure out how to get it all back together rope, spring, plastic guide insert, etc.... stihl 025 any suggestions
  • Anonymous Mar 12, 2014
    Pulled rope broke how to install new one
  • Anonymous Mar 14, 2014
    The rope broke when I tried to start the chainsaw. How do I replace it?
  • 62 Answers
Yes, it is possible that the spring needs to be pre-tensioned. its also possible that something was put together a little out of alignment, or some part is too tight and its too hard for the spring to wind in the chord. try to reassemble the chainsaw with a couple more turns on the spring and see if that helps.
paul
Posted on Oct 31, 2008
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Pull rope will not retract on a rlt30cet
Pull recoil and remove screw holding the string pulley. There's a spring behind it. Find where it hooks to the housing bend it to latch. This is what broke loose. Now wind it all into the designated spot. Attach string pulley and CAREFULLY put back together. Finally wind up insert rope and let it retract. This is a very difficult and frustrating job.
Feb 28, 2013 | Ryobi Garden
Bought mower used has nt been started in a while .when try the manual pull start the string does nt retract
sounds like the impeller on the underside of the starter mech is broken
Mar 06, 2011 | Garden
I pulled the starter rope out of the unit. How do I take the unit apart to re-wind the starter rope?
Take the cover off and look under it, you should see a plastic round disc that the rope winds on, You will need to locate the string and get it out of the cover where it passes through,once this is done, you will have to turn the disc the correct way to tighten spring ( you should be able to feel the pressure building as you turn, if not go other way, or the spring is broke, in wich case you need parts. If all is well, when you feel tension on it and have enough....not to much...just think about how much pull you had before it broke,because when the rope comes out it gets tighter towards full pull of rope, HOLD tension and put string through the hole on cover, once you have it through tie your handle back on, you should be able to release and jossle to get the rope back in the groove, Place on machine and see if you have enough tension that it will retract in cover when pulled and let go, if it does not you will have to repeat procedure, and tighten spring.....Do not get carried away with the loading of the spring......TIP you can shorten string if you just lack a little bit of it retracting in cover because it gets tighter when pulled out....Good Luck!
Nov 26, 2010 | Husqvarna Craftsman 200 Mph 430 Cfm Gas...
Homelite 25cc model UT20002A. How to repalce starter string?
Remove the shaft assembly at the motor, there should be one or two screws on the boom clamp. Remove the four screws holding the starter housing on. Inside the front of the housing is an air baffle you don't have to remove and the starter pulley. Remove it carefully, you don't want the spring to come out of its container. Remove any vestiges of the old starter rope and install the new one with no more than three or four windings depending on the thickness of the rope you bought. Install the pulley in the housing with the rope through the slot in the pulley so you can wind it a couple times to catch the spring and start the tension. It should be tight enough to just pull the string back into the housing. Feed the rope through the hole in the housing then through the t-handle and tie a knot so it won't pull back through the handle. Put the housing on the motor, no screws yet, and pull the rope out to make sure nothing is binding and the rope retracts fully into the housing. If it's too tight use the slot in the pulley to take one winding out. If the t-handle dangles, add a turn to the pulley. Reassemble housing and boom and you're ready to go.
Aug 23, 2010 | Homelite Mighty Lite Lawn Trimmer
The pull cord broke I just can figure out how to
1) Remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope.
This is the area that causes so many guys a lot of extra trouble!
2) Locate the string that is left and the hole it is threaded thru
3) Determine how much string has broken off of the rope that came out
*Note: if more than 1 inch is left, then the rope needs to be replaced
4) Obtained a length of rope appropriate for your engine, it is always better to have too much rope.
You can always shorten if it is too long.
Make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) Wind the rotor in the direction of what the rope would pull,
(this will tighten the spring) until the spring is completely wound.
Remove 1/2 to 1 revolution.
6) Install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
Tie a knot in the end of the rope, leaving a 3/8" tail free.
Then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
9) When the unit is functioning proplerly, re-install housing onto engine.
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Starter rope will not retract
Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil not recoilling good
hey fark
This is easy. Take off rope housing (four screws). Once off, pull the string out 3/4 of the way. Once out, tie string around spindle one extra time ( real easy just wrap string once more around winding spool ). This oughta make string snap back after pulls.
Jun 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
370 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
