Question about Traulsen Reach in Freezer - G12010
Evaporator coil iceing
Problem w/ the evaporator coil keeps iceing over. checked defrost heater, ok. could problem be with coil sensor? if so, how to you check sensor out?
    Genius:
  • 1,122 Answers
If you can put the frig. in defrost this will tell the sensor to turn on and you will see the heater melting the ice,if you can't put it in defrost and the sensor still has ice on it,simply put it in your hand,as your hand warms up you should feel the sensor pop,this pop tells the heater to turn off,if no pop the sensor is bad,if no ice on the sensor put it in a glass of ice,chill it down and do the same hand test,you can also use an omhs meter to check it,all the sensor does is open and close,let me know what you find-mike
Posted on Oct 30, 2008
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
I have a GE Profile refrigerator model #PFSSPKXBSS and the front control panel gets frozen. The only time I can change the settings is when the display panel goes haywire and starts changing all the...
solenoid for the ice dispenser flopper might get rusted, so the flop door would not close and freezer air would escape building up ice. need new solenoid assy for ice dispenser door and possible flopper.
Mar 27, 2015 | GE Refrigerators
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
What is er dh?
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
Dec 18, 2010 | Kenmore Refrigerators
I have a maytag MSD2456DEB...the freezer keeps icing over and stop cooling about every five days..any ideas
if it's ice check the drain if it's frost you have a defrost problem which is three things to check, defrost control, defrost t-stat and defrost heater
Nov 17, 2010 | Maytag MSD2456G Side by Side Refrigerator
Re GE TFX26ZP sid by side fridge Evaporator coil keep ice on it
the defrost thermostat should be clamped onto the evap coils..defrost timer should be under fridge. If this is a newer model, it might have an ecm ( comp control) on top of the compressor..
Sep 21, 2009 | GE GSL22JFR Side by Side Refrigerator
We have a Kenmore Elite Trio that keeps giving us an error message in the electronic window of er dH
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The coils keep freezing up.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Refrigerators
No longer keeps ice cream hard I have caccummed underneath
Jul 08, 2009 | Refrigerators
501f freezer ices up the evaporator. After defrosting it works well until it ices up again.
Could be a couple of things. First measure the resistance of the defrost heater that is mounted on the evaporator coil in freezer compartment. Make sure to disconnect the power from freezer first. The disconnect the defrost heater and measure with ohm meter. It should measure in the 20 ohm range. If it measures as "open" replace the coil.
Next suspect is the defrost timer mounted in the front of the compressor compartment. If the heater coil is OK, I'd just replace the timer. It is tough to test.
Finally, there is a defrost termination sensor mounted on the top of the defrost heater that shuts off the defrost heater when it reaches a high temperature. If the coil tests OK, and you are going to replace the timer, you may want to replace the sensor too. It is awkward to test, the temperature of the sensor needs to be be below room temperature to close. The cost of the sensor is low enough that you may not want to replace the timer, then test the system, and then have to go back in to replace the sensor later.
Jun 13, 2009 | Freezers
Traulsen Reach in Freezer - G12010 Logo
409 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
