Haier HDN455 Dehumidifier
Problem for Haier HDN455 Dehumidifier
My Dehumidifier was dead
By pzhuang on Sep 11, 2006
I purchaced my dehumidifier 4 months ago. Now, it totally doesnt work. no any signal on the leds, no any sound (nosies). I check the power cord and fuse, they are all ok. What is the problem with it? thanks.
Same Problem
Dec 29, 2008
-   I have an hdn655e Haier Dehumidifier which worked real well then just stopped. The control panel looks dead - no lights... same thing happened with a Maytag dishwasher and it turned out to be the panel. Think same thig is happening with the dehumidifier? -   cgcsuretycpa
Best Solution
posted on Sep 11, 2006
Helpful)
catriver
Rank: Guru
Rating: 94%, 3174 votes
PZ, about the only thing you can check is that the bucket switch is not hung up, or in fact a wire has not come off it. If you have power going to it, the next step would to be is to see if the on/off switch is working. Fact is you have a 12 month warranty on parts and labor and 5 years on the sealed system. Call for service, Catriver...post back.
Was this helpful?
Yes
No
Solution #2
posted on Oct 12, 2008
Very Helpful)
abc5
Rank: Apprentice
Rating: 100%, 7 votes
Check Zener Diode (ZD2) on the board to see if its shorted.
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #3
posted on Aug 01, 2009
Not Rated)
white710
Rank: Apprentice
Rating: 0%, 0 votes
It's probably the fuse on the control board. It happens to me often and I bought a box of fuses to deal with it. Betcha that's it
Was this helpful?
Yes
No
Popular Solutions for Haier HDN455 Dehumidifier
Questions and Unsolved Problems for Haier HDN455 Dehumidifier
Do you recommend Haier HDN455 Dehumidifier?
Answer
Answer
Unit runs but doesn't produce any water. I have cleaned filter periodically.Sometimes I collect... (More)
Answer
totally shut down, no lights , nothing. It just quit as if someone pulled the plug. Is there a reset... (More)
Answer
My 1 yr old Haier HDN455 dehumidifier has stopped working, although the green "running"... (More)
Answer
d2 shorted do not knows specs to buy a replacement
Answer
what is zd2. Mine is shorted and I do not know the specs
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier HDN455 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
