Question about Samsung CLP-500 Laser Printer
Colour Printing on a Samsung clp 500
Hi I cannot get the printer to print in colour but it produces perfect black and white. I have not switched off the colour printing and this has happened suddenly.
  • Prof G Oct 30, 2008
    Of course I have checked the toner level by the way the printer is a laser!!
  • 899 Answers
Color cartrige could be clogged , may need to be reseated, cartrige may be defective , or worse the printer cannot detect or command catrige to produce ink
try cleaning the cartrige with special cleaner kit
check contact points on cartrige for burnt spots
see if there is ink coming out of the bottom of the cartrige after cleaning
Posted on Oct 30, 2008
  • jason Oct 30, 2008
    1 x Toner cartridge ( Black ) - up to 2000 pages, 1 x Toner cartridge ( Cyan ) - up to 1500 pages, 1 x Toner cartridge ( Silver ) - up to 1500 pages, 1 x Toner cartridge ( Magenta ) - up to 1500 pages
    if none of them are working , then there is a problem in the printer
    Scholar:
  • 155 Answers
Try to print a test page directly from the printer.not from the computer.if the print comes proper that means the printer is perfect and you have to adjust your computer settings.
if the printout does not come properly when you directly give a test print from printer that means its definately the cartridge issue.
also try reloading the drivers of the printer again if there is a printer setting problem and its not getting adjusted.reloading the drivers again will automatically create new proper settings without doing anything.
thanks.
    Brigadier General:
  • 3,614 Answers
Did you change the ink before this error happen...
check the cartridge if there's still a color ink on the tank.
  • micromaster
    micromaster Oct 30, 2008
    have gone checking it manually or by the system utilities that came with the printer driver.
  • Samsung Master
  • 19,396 Answers
Try unplugging printer from the power and connecting it back.
Try also extracting all toners and putting toners back.
  • Ginko
    Ginko Oct 30, 2008
    Try First unplugging the printer from the main power, waiting five minutes, and connecting it back.
    This will reset the problem in case it is a setting pronlem.
    If this does not work, check on the computer, go to printer settings and check that the print settings are not set to back and white.
    If that did not work, try extracting all toners cartridges, power cycle the printer, and fit the toners back, following the toner installation cycle.
Samsung CLP-315 colour laser printer - is it true that you cannot print only with the black toner cartridge, if one or more of the colour cartridges is empty? I only need to print black!
Yes, it is true that most of Color printers will not allow you to print document if one or more of the recommended Cartridge of the printer is empty or removed from the printer. for printing only black, the better option will be to change your printer settings while printing a document. ex: when on a document ,and your press Ctrl+P for document printing, there is a option where you can select print color as black and the printer will print your document in Black only.
Feb 05, 2010 | Samsung CLP 315 Laser Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
Unwanted line down centre of page
you need to reassemble image unit and clean completely
if you dont know how to do just bring it your printer to technicians
Jan 06, 2010 | Samsung CLP-510 Laser Printer
Black toner
I had the problems with white smear type fading on one side of the page , when pritning black, but colour printing seems OK. Did everything suggested in the manual and more. Changed toner. Been working on it a week.  (I got 2000 pages out of that thing).
Now I have the solution. Bin the Samsung and buy a Canon.
Lee
Sep 01, 2008 | Samsung CLP 300 Laser Printer
Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Jul 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Deactivating colour printing
You may do it in your Software Side While Printing. Do notalter Hardware settings for this Purpose. Because its meant for color Printing.
Regards
Rafique
Feb 22, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-550 - magenta bands
I have the same problem. Any solution?
Dec 19, 2006 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
140 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
