Question about HP Photosmart M407 Digital Camera
My camera will not turn off !!!!!
My hp photosmart m407 will not shut down, sure if I take out the batteries it goes off but the lenese is still out. When the batteries are in the screen will display the last image taken but nothing else I cant get to the menu the flash or even the zoom. If the blue arrow button (the one that shows the saved images)was jamed would this happen? any button I press turns the image on and off.
  • Anonymous Nov 19, 2008
    I had the same problem with only the camera turning on and taking a picture, it would not turn off, zoom, the display and menu also did not work. I did exactly what was posted on this web site and it worked perfectly after that. I had to move two round pieces back into their places on the electronic board under the LCD screen inside of the camera after I took it apart. I was amazed that this worked I wish someone would tell HP Technical support as I was on-line with them today and they had no solution for me. So happy This web site helped me out! Now I will not have to buy a new camera.
WOW: All three Solutions Work Fine.
I Removed the 6 small bolts and took the camera apart.
lifted the tape and cleaned the contacts u;nder the tape with alcohol, let them dry then replaced the tape, lineing up the contacts on the tape with the ones on the body of the camera. Put the camera back together and put back the 6 bolts, inserted the batteries and presto: the camera worked. Thanks for the info , it really worked. Wes Reed
Posted on Sep 13, 2010
  • Mario Turk
    Mario Turk Apr 04, 2012
    thanks for all this solution,I removed the 6 small bolts and one small (CU)contats(over the foil) in camera was in contact with metal board on LCD screan and make a shock with everything in camera,so I pull ut the foil(tape) and put in on place ,and digital camera HP FCLSD-0504 now is working
The solution in my case is the same solution tells
the user scrajmer,,,,
my camera is hp m407 and goes on and dont power off
and buttons dont work,,
open camera (6 small bolts)
and check the section in the lcd..
the contacts are under a film tape,,
in muy case 2 contacts are short,,
i change the tape and correct the position of contacts,,
and vualaaaaa..
the camera works fine,,,,
try it!!!
Posted on May 02, 2008
Yes, I had exactly the same with this HP camera. I solved it by removing all 6 bolts, gently removed the front and the back of the camera (so your camera ends up in 3 pieces) and put everything together again. Nothing more than that. And suddenly all works fine again. Thanks for the hint!!
Posted on Oct 18, 2008
  • 188 Answers
In one of the same case with the same camera and model i found the gum on the plastic tape to hold down the panel switches at position got loose, making the switches short permanently. once removed and placed back in proper place the camera started working fine.
Posted on Sep 11, 2006
Where to get parts: ;photo card, charger or batteries, instruction manual?
Start with http://www.hp.com
Enter "M407" into the search box and go from there.
Oct 26, 2010 | HP Photosmart M407 Digital Camera
Turn on cameron switch, power comes on then goes off
are the batterys replaceable , i hope so , sounds like
they arent holding a charge .
If it takes AA s try a pair of akaline .
Aug 13, 2010 | HP Photosmart M407 Digital Camera
Battery won't charge on my HP photosmart M407. Batteries are new. What else might be wrong?
It could be something wrong with the power board. If you have an external charger to charge the batteries. After fully charged tried to take as many pictures as you can. If the battery discharge fast, that mean something is wrong with the power board.
May 19, 2010 | HP Photosmart M407 Digital Camera
Were can i get manual for m407 photosmart camera ,hp regulatory model fclsd-0411
Everything is under Hp website. i did download all my stuff including firmware etc from hp.
Mar 23, 2010 | HP Photosmart M407 Digital Camera
I lost the power adapter for my M407 digital camera.
You can purchase a ac/dc adpater with multiple plugs from Radioshack or any electronic store for less than $10. Make sure the votage is 3.3 to 4v that you need. Or you can pay about $30 from ebay. Make sure you take the camera and try the plug on so it will fit in. Good luck -James
Mar 28, 2009 | HP Photosmart M407 Digital Camera
HP Photosmart M407 Digicam
The issue is probably the button board on the camera. To open the camera, remove the six screws and pry open the camera from the bottom of the camera to remove the outer casing. Turn the camera so that the LCD is facing. Remove the aluminum frame around the LCD that holds the button board in place. Check the button board for mis-aligned or damaged discs (ie playback or view buttons) The discs are taped and may creep out of position. If they are out of position, push them back with the blunt edge of a screw-driver. If it looks fine, reassemble the camera.
May 01, 2008 | HP Photosmart M407 Digital Camera
Hi, can you help me with this?
is it a brand new camera? how long have you had the camera? are u puttin the batteries in the correct way? maybe u can try different batteries for now see wat happens if not write me back.
Hope this helps!!!
Apr 19, 2008 | HP Photosmart M407 Digital Camera
HP Photosmart M407 Digital Camera Logo
165 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
