Question about Panasonic CT-32G11 32" TV
27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
You press the power button, and the red light turns on then instantly off. I will then unplug the chord from the surge protector, or turn the surge off entirely. 10 seconds later, I will plug the chord back in or flip the surge back on. You can see a spark from outlet where the chord is plugged in. However, if you then press the power button, the tv will come on. The top few inches of the screen will have a distored see through look to it. After a few minutes, this will subside. When you turn the tv off, and try to put it back on, you have to repeat the above drill. Any suggestions? The tv is one year old.
  • 2 more comments
  • nightbreaker Nov 19, 2007
    I have a 3 year old panasonic Tau, the thing just shut off and is dead, no red light. Any ideas??
  • Garfieldo Mar 23, 2008
    I have a similar problem with a 27 inch Panasonic TAU, TV 3 yrs old, worked fine yesterday, won't turn-on today! Any ideas? Is there a reputable repair shop in West Los Angeles someone could refer me to?
  • jagodzinskij
    jagodzinskij May 16, 2013
    It's probably the sc board. Mines been replace twice and just broke again this week. This time sparks turned to flames and was outside of tv casing about 3 inches
  • jagodzinskij
    It's probably the sc board, mine has been replaced for same problem twice and it just broke again this week. Had a Panasonic tech here tonight and when he powered it on, sparks turned to flames and came out of back casing about 3 inches. Panasonic still won't do anything about it. Very poor customer service. Going to make all formal complaints tomorrow.
IM HAVING THE SAME PROBLEM. SEEMS TO ME THAT THERE ARE DEFECTIVE CAPACITORS ON THE VERTICAL CUIRCUT. THATS WHY WHEN YOU UNPLUG THE UNIT THEN REPLUG IT IT CAUSES A SPARK. YOUR JUST SIMPLY RECHARGING THE VERTICAL FILTER CAPS. WHICH YOU CAN SEE THEM GOING BAD BY THE HORIZONTAL WHITE STREEKS ACROSS THE SCREEN. REPLACE WITH A HIGHER VOLTAGE RESISTANCE BUT KEEP THE UF VALUE THE SAME......
Posted on Sep 24, 2007
    President:
  • 3,130 Answers
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Posted on Sep 11, 2006
    Problem Solver:
  • 17 Answers
Do you get extension corn in Iowa?
Posted on Jul 15, 2009
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My phillips 51pp9100d wont powerer on, the powrer button blinks nine times thats it
Try turning the power on using both the remote and the power button on the front of the set. if the set turns on using the power button on the front of the set, there is a problem with your remote.
If the set turns on using the remote but not the POWER button on the front of the set you may
If the LED light on the front of the set blinks but does not turn on when you press the POWER button on the remote or front of the set If the LED light does not blink when you press the POWER button try unplugging the set from the power outlet for 10 seconds. You should also try plugging a lamp or other electrical appliance into the outlet to make sure there is not a problem with the outlet. Sometimes an electrostatic discharge may cause the set to lock up and disconnecting the power resets the set. If problem persist, If using a surge protector, try plugging the set directly into the wall outlet. An electrostatic discharge could have tripped the breaker in the surge protector.
Sep 01, 2011 | Televison & Video
My hp printer 6110 officejet all in one keep giving message scanner failure when i want to print something
Please make sure that the printer is connected to a wall outlet and not to a surge protector because surge protector distributes the total electric supply equally to each and every device connected to that surge protector. Printer might work and might not with a surge protector but it will always work fine with a wall outlet till the hardware of the printer and power chord, adapter are working fine.
some times scanner failure error comes if it is not getting enough power supply.So if it is connected to a surge protector then I will suggest you to disconnect it and connect it directly to a wall outlet.
Now scan or copy any document and see if something happens.
If not the do check while you press scan or copy button the scanner light is moving or not?
If scanner light is not moving then do a hard re-set.
Hard Re-Set :
- disconnect power chord from the back of the printer and then from wall outlet or surge protector.
- wait for 40 secondsand then connect the power adapter to wall outlet and then to the back of the printer. The try to scan or copy....still not working then check if the scanner bulb is glowing or not?
If scanner bulb is not glowing and if you dont hear any noise while you press scan or copy...then printer hardware has gone bad and you need to replace the printer
Feb 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
Trying to change fuse in wii but need to know where to find it
Is your Wii just not turning on, no indicator lights? No red, yellow, or green, and pressing buttons doesn't work? Try re-setting the AC adapter.
If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 21, 2009 | Nintendo Wii Console
The power button...console will not turn on. No
I see this issue on every site and Wii forum I visit. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Nov 16, 2009 | Nintendo Wii Console
My daughters xps 200 won't start, she presses the button and nothing. She has checked the surge protector that it is pluged into and it is OK... is there a reset button is there was a power surge??
most surge protectors have some sort of on/off switch and a reset button. If there was a surge then you would need to pres the reset button to get the surge protector to function again. If there was no surge then try using the on/off switch on the surge protector to see if that helps. Also try simply unplugging the power cord from the back of the desktop while the computer is turned off. This will sometime also help.
Oct 12, 2009 | Dell XPS 200 PC Desktop
32 '' CRT won't turn on afer power surge
Follow these steps to troubleshoot the television not turning on:
Make sure the AC power cord is connected securely to a working wall outlet.
NOTE: If the television is plugged into a power strip or surge protector, unplug it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Press the POWER button on the television.
Press the POWER button on the remote control that was supplied with the television.
NOTE: If the television turns on and off using the POWER button on the television but does not respond to the POWER button on the remote control, troubleshoot the remote control.
Unplug the television power cord from the electrical outlet for 30 seconds.
Plug the power cord back into a known working electrical outlet.
Attempt to turn on the television.
IMPORTANT for the following models only:
KDF-E42A10
KDF-E50A10
KDL-V26XBR1
KDL-V32XBR1
KDL-V40XBR1
Unplugging the above television models from the electrical outlet may only be a temporary fix. The problem may reoccur after several months of use. To completely resolve the issue, a software update is available.
For all other models, service will be required if the troubleshooting steps do not resolve the issue.
Aug 01, 2009 | Televison & Video
My wii won't turn on
You likely had a power failure. You need to reset your AC adapter. Here's how:
  1. unplug the power cord from the wii. Unplug the adapter from your surge protector or the power outlet.
  2. wait 90 to 120 seconds. (Some people say to wait 30 seconds. Wrong! At least 90 secs is required for the AC adapter to rest.
  3. plug stuff back in and you're good to go.
NOTE: electronics like your wii, ps3, etc should be protected from power surges and power failures! Plug them into a good surge protector. Always!
Jun 27, 2008 | Nintendo Wii Console
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Televison & Video Logo
1,083 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
