Question about RCA F35670MB 35" TV
TV won't power up and blows the fuse
Tv worked great (fantastic picture as usual) one night and the next morning it was completely dead. No power. We took the back off and found the fuse and replaced it. As soon as we plug into power source the fuse blows (green light flashes). Any ideas what it could be? Worth repairing a 10 year old tv? The television is very heavy and I'm only going to move it once. Thanks.
    President:
  • 3,130 Answers
A 10 year old RCa most likly has a bad Horizontal output transistor as well as the main High Voltage transformer and The transformer is no lonmger available from RCA. The replacement wont last longer then a year if your lucky. My advice on a set this old ?? Buy a newer one!!
Posted on Sep 11, 2006
Alba 32inch hd lcd tv
The internal power supply may have failed.
Nov 14, 2013 | Televison & Video
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
I have great sound on my tv but there is no picture
i had the same problem take the back off an unplug the lcd an give it a blow put bit all back together an fany's your ant
Apr 24, 2010 | Sanyo DP37647 37 in. LCD TV
Have sound but no picture. Turned TV off last night and when I turned the TV on this morning there was good sound on all channels, but there is no picture. Just a black screen
is hv circuit problem a power transistor to 25KV transformer maybe dead, check the HV Circuit, or 1XXV output from Mains transformer the fuse maybe dead
Mar 11, 2010 | Sony KV-36XBR450 36" TV
35" RCA 35" Entertainment Series - PIP
ok is the set completlely dead. DOEs the Led on the front flash. if it does not flash this is an indication of a primary power interuption. POSSIbley main fuse. Now generally the main fuse does not blow unless there something else wrong. some other component shorted. Now if the light flashes then this is an indication that the main fuse is still good and that the processor is getting power and that it has detected a condition that requires it to shut down. ussaly a high voltage issue
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi big screen model CU5003D purchased 9/1991
Most likely the power supply has failed or has detected a fault in another circuit. (The CRT-type rear projection TVs were prone to convergence amplifier failure, which could blow internal fuses; you may have a bad convergence amp that doesn't quite blow its fuse but still overloads the power supply. Usually they go out completely; the TV still runs, but one or more colors in the picture distort into a bow-tie shape.)
The TV was obsolete 15 years ago, so it would probably be impossible to get a replacement modules. A technician may be able to repair the TV by tracking down and replacing the bad component, but you would likely pay well over $100 in bench charges.
You can get a 50" LCD TV that uses less power and takes up much less space for $300-$600, has nearly twice as sharp a picture, and works with modern digital TV inputs.
Jul 10, 2017 | Televison & Video
No picture, sound and/or stanby indicator light...dead!
Loss of low voltage supply has happened. This regulates the ability of the set to sense the remote as well as the front panel switches. Could be anything from open T1 secondary to a regulation problem; i.e. excess drop from defective component....accordianman
Oct 20, 2007 | Sony KV-32V16 TV
Power
if the tv set have no sound no picture, they call it dead set your tv need a repairman technician to trace your tv what was part was damage. but if your tv has standby mode mybe you entered the timer code.
Aug 20, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
