BUSH TV no sound through hdmi
BUSH TV's from Argos.... if your trying to connect an item of kit to your Bush tv via HDMI and you have no sound... get the instruction book out and read it... basically it says turn OFF (thats off at wall if needs be and to not standy by) both pieces of equipment connect lead and then turn on again... hey presto sound via hdmi ! Bizzare I know but it worked for me. After much messing around with almost every setting on both bits of kit, grrrr note to self... when wife says read instruction like Nike "just do it" . Best of luck hope it helps you
SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
Posted on Aug 25, 2007
Cybertech
  • 149 Answers
SOURCE: Connection help with receiver and lcd TV
depend on what you wants to do. if you wan to get sound from your tv on receiver connect out from tv to in on receiver if U have optical out from tv send this to optical input on your receiver and set up your receiver to impute to digital HDMI carrie sound and video...
(My Denon receiver set-up shows an HDMI cable going from the Video Out on the TV to the HDMI MONITOR OUT on the receiver)
OUT TO OUT don't make sense ...could be out to impute you may have HDMI going from receiver to TV and other HDMI imputs on receiver to use receiver as distribution unit say you have satellite HDMI, DVD HDMI, Computers HDMI IMPUTE all of this connected to your Receiver and the HDMI monitor out from your receiver connected to TV so now you may select any of this sources to wach In your TV and lessen trough receiver speakers
Posted on Apr 10, 2008
dsacco86
  • 1077 Answers
SOURCE: HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
Posted on Feb 16, 2009
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
  • 630 Answers
SOURCE: Bush TV and Setting Default Inputs
Not an expert on this model but generally if you switch the TV on by pressing the remote's power button it will come back using the input you previously used. If you press a channel button it will come back to DTV.
Posted on Jul 19, 2009
I have Bush TV, a Virgin Tivo box connected by HDMI & a Wii connected EXT1. Every time I turn the TV on it says no Video connected & reverts to EXT1. How can I get it to start with HDMI as standard?
Try turning TV off and all devices connected to the TV off, Turn the TV on and then turn on the device you wish to use and that should activate the TV circuitry.
Sep 02, 2017 | Bush Televison & Video
How do I get my Bush tv to start in HDMI mode not tv
you cant,the tv will always come on the tv channel. you can turn the item off that is plugged into the hdmi port then back on and it will take over the tv channel and switch to hdmi. so on a night turn off the item plugged into the hdmi port and on a morning after your tv has turned on then turn on the hdmi item and the tv will switch over itself
May 30, 2015 | Bush Televison & Video
Bush hdmi port broke?
hi just take it back get a better make tv like a panasonic thanks
shaun
Apr 17, 2017 | Televison & Video
HDMI input doesn't work
replace Main PCB (it has the I/O ports & circuitry on it)
Nov 26, 2013 | Bush Televison & Video
Sound problem between bush 47" and v+ via hd
Hiya
We are having the exact same problem, our 3D tv works perfectly with the V+ box when connected via the scart but when its connnected via HDMI cable then there is no sound at all.
Did you manage to get this problem resolved and if so, how? Thanks.
Mar 14, 2012 | Televison & Video
Acer aspire x3200 wont register my Bush plasma as second screen via HDMI input. any help would be much appreciated.
Try booting the machine with the bush tv connected, usually this will find the screen, then go into your desktop settings on the pc and set up the displays for size and position
May 05, 2011 | Acer Aspire X3200 PC Desktop
No sound or picture from dvd
And you have selected the HDMI2 input in the TV menu? If yes, try the dvd on another TV, if you have one. Also try reversing the HDMI cable.
Jul 01, 2010 | Bush DVD2038 DVD Player
Bush 32" LCD 1080p tv
Is this the BUSH "LCD32F1080P" ?
Bort from Argos for £330 (then £370 now £300)
Cos I noticed mine doin that aswell, I thrt it mite be cos im using an old ASDA HDMI cable... but now i saw your post.
Nov 05, 2009 | Televison & Video
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
Televison & Video Logo
1,359 people viewed this question
Top Televison & Video Experts
