Question about Sentry Fireproof Safe
S3407 we have a sentry safe s3407. but no one can find this instructions to use it. can anyone help us either create a new code? or have anywhere we can print instructions on how to use it please?
  • 10 Answers
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
Posted on Feb 18, 2008
SOURCE: Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Posted on Jan 20, 2009
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: sentry codes v260
Call SentrySafe @ 1-800-828-1438. They may require you to send a notarized letter to their Linden Ave site in Rochester NY
Posted on Aug 24, 2009
I have a sentry safe model OS0810 and i need a factory code as I cannot recall my pin code
There is no 'factory code'. If there was anyone who knew it could open anyone's safe. You will need to take it to a locksmith. They will drill the door and put a new one on for you.
your safe here
http://www.sentrysafe.com/Products/230/OS0810_Electronic_FIRE-SAFE_
What they tell you if you have lost your combination. You may be lucky if it hasn't been changed.
Sentry Safe Lost Your Combination
Dec 09, 2015 | Home Security
Need factory code for sentry gun safe
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Dec 21, 2012 | Sentry Fire Safe 24-gun Safe Combination...
What is the code in enterfactory
Hi.
Hi. There is no factory fixed code. Thieves would be the first to benefit from such feature! The factory code is uniquely associated to the safe serial number and it is stored in Sentry protected database. When original code is lost the only way to unlock the safe is bay following Sentry's procedure.
Contact Sentry immediately. They will first try an emergency unlock code, and then they will give you instructions in case the safe must be serviced. Here the contact: Call or Email Us
Here general instructions about what to do when combination does not work. Instructions are addressing lost combination.The procedure is the same in all cases when combination does not work (malfunctions, lost combination etc.) . Please contact sentry and follow procedure to get the safe open.
Regards.
Ginko
Oct 05, 2011 | Sentry Fireproof Safe
Csw3607 sentry safe will not open. when i use my 5 digit code the red light beeps 5 times. when i use the factory code it does the same thing. Sentry has told me to take it to a locksmith and have them cut...
I hate to tell you, I just had this same problem on a brand new safe (x-mas present) and ended up having to crack it open. Unfortunately, from my extensive research on this problem on Sentry Safes it turns out that they use an encoded IC chip on the solenoid and if either a serial wire breaks going to the board or the IC chip fails, you get the 5 beep-of-death error. Needless to say, I'm thoroughly disappointed in Sentry and will discourage anyone from purchasing their products!
Dec 10, 2010 | Sentry Fire Safe - Safe - DS3607
Somehow can open my sentry s3877 with the keypad.
A Safe and Vault Tech Will confirm that once you change the batteries the user code will erase and you will now have to enter the factory default that is in the owners manual and then use the programing instructions to program a new user code.
Jan 07, 2010 | Sentry Fireproof Safe
Need to get factory code for sentry safe
instructions are located link above.
mj
Mar 26, 2009 | Sentry Fireproof Safe
Mar 22, 2009 | Sentry Fireproof Safe
I HAVE A SENTRY SAFE A3860 I NEED TO OVERRIDE THE ELECTRONIC CO
look instructions are located link above.
mj
Mar 15, 2009 | Sentry Fireproof Safe
CAN NOT OPEN MY SAFE, MISPLACED INFO, LOCKED CODE NUMBER IN SAFE. ELECTRONIC FIRE SAFE NUMBERS ON OUTSIDE OF SAFE OA3817 BA69609
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements
May 01, 2008 | Sentry Fireproof Safe
How to open my safe with the code
How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Apr 18, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
247 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
