What amp should i get for two pyle red label 12" subs? can i use 1600 watt amp a audiotek
SOURCE: i have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
SOURCE: 2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
