Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Half print from the Bypass tray:
My mfd is Xerox wc pe16, when ever i want to take a photo copy from the bypass tray half print is coming. please sujjest me one solution on this problem,
  • 208 Answers
SOURCE: Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Posted on Nov 28, 2007
  • 2072 Answers
SOURCE: PE16 xerox
You have to remove the 4 screws from the back of the machine, and remove the back cover.
Then remove both side covers. They are on with plastic tabs on the sides. They will with some work pop off.
Be sure NOT to break the wire to the speaker when removing the covers.
You next have to remove the connectors from the document feeder and scanner located on the right side of the machine looking from the rear. Also unscrew the ground wire.
Remove 2 screws from the back portion of where the scanner is connected to the frame, just above the fuser.
Slowly remove the scanner/feeder assembly. They interlock into the front of the machine.
Remove the document feeder from the scanner. Just slides out.
Lay the scanner glass side down.
Remove the screws holding the controle consol on, remove and unplug the consol. Then take the screws out of the scanner, from the top, that hold the scanner together. There are a couple of tabs you need to release to seperate the upper and lower scanner.
Then you have to carefully pop the tabs in the scanner head to release the lamp assembly from the CCD assembly to clean the mirrors, being very careful not to break one of the mirrors in the process of popping the tabs to realease the lamp bracket assembly.
Clean with a soft cloth and glass cleaner, then repeat the procedure in reverse to put it back together.
Take your time and be sure you get everything plugged back in.
You just about take the machine down to nothing to clean the scanner.
Not difficult, But please take your time and make notes, or careful mentally make notes so reassambly is easier.
Hope this helps.
Posted on Jan 28, 2008
IB4G2008
  • 3587 Answers
SOURCE: HP Designjet 110 plus nr print/feed problem
hmmm..sounds like a memory overload..shut down machine, let the memory clear, and maybe reinstall the print management software..print queue issues are almost always from overloading the memory for the printer..
on the feeder issue, check for paper caught in tray or path, and clean the rollers too.
check your computers warranty here 4 FREE
Posted on Feb 27, 2008
SOURCE: xerox PE16 cru fuse problem
mr jaiku thank you
Posted on Aug 16, 2008
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
Change the paper settings of bypass tray for required size in settings menu.
Nov 21, 2014 | Xerox WorkCentre 5687 5675 5665 165 275...
HOW do I get my printer to stop trying to print from the bypass tray?
check the printer properties in Windows Control panel and see if printer settings are set to bypass tray
Sep 19, 2014 | Xerox Office Equipment & Supplies
How can i avoid label sheets getting stuck in phaser 8560
1. Make sure you are feeding the labels from the bypass tray, not from the cassette.-
2. Make sure the labels are for Laser printers, not Inkjet printers.
3. Do not try and re-use a label sheet that only was half printed on.
4. When you put the labels in the bypass tray, set the paper type to labels...this slows down the print process so they won't get jammed.
Jun 02, 2014 | Xerox Phaser 8550DP Printer
Xerox workcentre c2128 When i put paper in bypass tray, sensor dosnot detect this paper
You must manually define the papersize and orientaion of bypass tray at the printer console or printer driver.
Then print bypass tray (e.g. Tray6 on our Xerox).
Apr 13, 2014 | Canon Computers & Internet
I have a Xerox 7345. Instead of printing red it
In one of these diagnostic areas you will find an auto gradation adjustment, perform that. Here are the steps.
To enter the CE mode:
  1. Press and hold the 0 key for 5 seconds, then while still holding down the 0 key, press the Start button.
    The CE Access Number screen will appear.
  2. Enter 6789 and press Confirm.
  3. The top most area of the UI display will be reversed to let the user know that the mode has changed to the CE mode
  1. Enter the Diagnostic mode.
  2. From the Common Settings screen, select Image Quality Adjustment.
  3. Select Calibration.
  4. Select the button of the Screen Type to be calibrated, that is, Copy Job - Text, Copy Job - Photo, Print Job - Text, or Print Job - Photo.
  5. Press the Target button and then select the type of jobs to be calibrated, that is, Copy & Print Jobs, Copy Jobs Only, or Print Jobs Only.
  6. WC 72XX only: Load A4 paper in the Tray 5 (Bypass). Press Save.
    WC73XX only: Select a paper size and type using the paper supply button
  7. Press Start. The auto gradation routine will run and a message will display upon completion.
  8. Take the print from the output tray. Follow the instructions on the screen to complete the color correction.
Jan 15, 2010 | Xerox WorkCentre M-24 Color Copier
Printer trying to print from the bypass tray
check your software setting OR delete and re install your software
Sep 19, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
PE16 XEROX Printer pulls additional empty half page
There is a little gray pad in the front of the paper tray that is responsible for stopping extra paper from being fed. It is about a quarter inch wide and maybe an inch and a half wide. It really needs replaced. I am sure yours is slick as all get out.
You can however take some scotch brite in the meantime and rough it up some.
You can call 1-800-828-5881 and follow the prompts to order one, They are not very expensive.
Jan 20, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Printer 4500
Checkthe paper size (paper,driver,etc)
try printing from the bypass tray
try printing an internal test page
try printing the usage profile (internal) this may give you a fault code
Jul 08, 2008 | Xerox Phaser 4500 Printer
Solution
    3. Click on Options
    6. Click <OK>
    • Paper Size: COM10
    • Stapling: None
  • Under Tray/Layout
  • Click <OK>
  • " <OK> again
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
59 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
