Question about Pelco DX1000
D9216v dvr reset - Pelco DX1000
I purchased a NIGHT OWL modelxhd50288p 8ch v 2tb 5mpcam system and forgot pw and dvr is locked how can i reset it
hello friend. idont known much about this night owl model dvr.but i can suggest small technique which we use i n chinese dvr.open the dvr look for 2030 small battery fixed in the board remove it .start your dvr reset to factory setting once then insert the battery again.i hope your dvr is ready.
Oct 25, 2017 | Night Home Security
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Oct 07, 2017 | Samsung Home Security
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
Sep 18, 2017 | Samsung Home Security
My Samsung dvr model SDR75300n can't not reset my passwood.
you need to do on the dvr .remolt settings you cant do needs to be done by the dvr
Jun 15, 2017 | Samsung Cameras
How do i reset my dvr
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:-
Jan 13, 2016 | Swann Communications Home Security
How do I reset the admin password in this dvr?
REMOVE THE ON BOARD BATTERY IN DVR FOR 10 SEC AND PUT AGAIN THAT GONNA RESET IT
Mar 19, 2015 | Home Security
How to reset my dvr rds--p5102
Depends on what you mean by reset. If you are doing a default reset yes you will lose all settings in the dvr. You can't normally do this without logging in or getting a back door code from the manufacturer. If you mean a power reset all data will still be there but you still will not be able to log in.
Sep 09, 2014 | Home Security
Qihan dvr super password
Forget the DVR password, how to generate a new one with software ...
www.hkvstar.com/.../forget-the-dvr-password-how-to-generate-a-new-one-with-softw...
Nov 4, 2013 - If you forget the DVR password, you can use the password generation software to get a new super admin to unlock the DVR.
Reset DVR password to Factory default - • CCTV Forum
www.cctvforum.com/viewtopic.php?t=39460
Jan 26, 2014 - 15 posts - ‎4 authors
I have a DVR shown below and I am not able to reset the system to the factory default. It is an 8 ch standalone, unbranded, no make or model ...
How to - Zmodo DVR Resetting to Factory Defaults - YouTube
? 0:46
https://www.youtube.com/watch?v=rT-cUgWbHQM
Sep 24, 2009 - Uploaded by CCTVHotDeals
This video shows how to reset your DVR to factory defaults. ... Reset PasswordDVR H.264,AHD, With Super ...
CCTV H264 DVR password reset superpassword super password ...
https://dashcamtalk.com > Home > Forums > General Forum > Off Topic
Jan 2, 2015 - 12 posts - ‎7 authors
I was searching on internet for this problem because I set the password one year ago, I forget it and I want to reset the password. I have a ...
How to reset password ?
support.qube.asia/127247-How-to-reset-password-
STEP 2- Open the cover of the DVR. STEP 3- Remove the CMOS battery. STEP 4- Power On the DVR. STEP 5- Enter a password. Username: As given.
[PDF]Qihan NVR manual
www.riasztobolt.hu/pictures/down/en_tmanual_quihannvr.pdf
Support modifying the user's authority and password. Subdivide the authorities (preview, ... DVR: Digital Video Recorder. IPC: IP Camera. IP PTZ: Network High ...
Aug 13, 2014 | Home Security
Pelco DX1000 Logo
146 people viewed this question
Top Pelco Televison & Video Experts
Marvin
Marvin
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
