Home Logo
Anonymous Posted on Feb 29, 2012
Jacuzzi pump motor leaks at the seal - Home
Anonymous
Level 2:
Scholar:
  • Expert 111 Answers
  • Posted on Mar 02, 2012
Anonymous
Expert
Level 2:
Scholar:
Answers
111
Questions
0
Helped
69414
Points
122
This means that your pump seals are bad. They are an inexpensive part to replace luckily, but removing the impeller can be tough. There are a number of different Jacuzzi motor/pumps so be sure to get the right seal kit.
Briefly:
The trick is to stop the shaft from spinning while you loosen the impeller. FYI they don't usually come off easily, the older the pump the harder it is to remove the impeller.
On the rear of the motor there is a slot where you can put a flat screw driver into the back of the shaft to stop it from spinning. Once the impeller is off you can remove the volute (rear housing) and change the seal.
Let me know if you need more help.
It's a j460 model that leaks.
sounds like it ran dry and burned up the seals between the pump and the motor
My Jacuzzi pool pump Mod.# 7lrc-48-s1/b is leaking from between the head and the motor housing.
this indicates a "mechanical seal failure" this will require replacement of said seal or entire pump
Leaky Motor
This sounds like it could be the shaft seals, which is a cheap fix.
The Jacuzzi Magnum calls for seal 35-423-1021
You might consider replacing the seal plate O-Ring as well. - 35-105-1120
Jacuzzi pool pump leaking
Where is it leaking? if it is still leaking between the wet end which is the black plastic water housing and the motor then the seal is not properly set.
Rod
US Parts Center
1helpful
I'm trying to find a seal kit for a Emerson spa pump Model #T55MWCCE-1208
The seals are specific to the Jacuzzi pump housing not to the Emerson motor. Most Jacuzzi pumps use the PS-200 or PS-201 seal (some have it listed as AS-20X) here is a Pump Seal Cross Reference.
Pool pump running low psi
your pump should be just fine once the water starts flowing again. You may have run it too long without enough water to cool the seal.
If it is leaking water between the Jacuzzi Pump housing and the motor then you will need a new pump seal. Those are common pool parts.
Rod
US Parts Center
888-521-6183
1helpful
How to separate the two impeller flanges of a jacuzzi pump to access the impeller in order to remove the wet end from the motor OR is there some way to remove the wet end of a white JWB 60C Ser no. 06785...
That is an old sealed Jacuzzi pump that can not be repaired. It is one of many reasons why Jacuzzi never did well in the pump business and has gone from owner to owner over the years. Unfortunately your pump is not repairable without destroying it in the process.
Wet ends may still be available. The part numbers I have are:
850100 .5/.75 HP
9011000 1 HP
850200 1.5 HP
856600 2 HP
0199000 Gasket (2 req’d)
4516000 Flange, 2”
Good luck,
John
2helpful
I have a jacuzzi magnum 1500 pool pump which leaks. I changed the O-ring and it still leaks. If I have to change the seal on it, how do I change it. I tried undoing everything on this pump. Thanks!
You need a 201 seal for the pump. Most electric motor shops that work on pumps and of course pool store carry these. If you are unfamiliar with how to change the seal, the charges to have it done are usually low. We charge $15 - $30 depending on how much of the pump is brought in and therefore remains to be taken apart to replace the seal. The seal is about a $5 item.
If trying yourself, you will need to completely disassemble the pump, lock the motor shaft at the rear of the unit, spin off the impeller, and replace both halfs of the seal.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
