Question about Symbol MC9090 Barcode Scanner
Wireless configuration problem. It lost parameters I had imposted.
I link to a wireless red and I set any parameters like static IP or the password of wireless. When I reconnect to the same wireless the barcode loses those parameters.
What must I do?
Please reply...
If you are using a MC909X, after entering the static IP address and WEP key etc. via the Wireless Configuration Editor, you can export the profile you created by going to the Manage Profiles area, tapping and holding the profile name until the menu appears, then select export, it will create a registry file in the Application folder of the device that will persist after a cold boot, and the settings will will not be lost.
Posted on Nov 06, 2008
I lost my cd for my d link wireless router and i am unable to set up my new computers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | Computers & Internet
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
I have no internet connection with the router but can surf without the router and only my modem
You need to configure your router WAN settings as your internet service provider.
If your ISP gives you static ip then configure it as static.
If ISP gives user name and password to connect inteernet then configure router as pppoe.
http://192.168.0.1
or
http://192.168.1.1
Click on wireless settings enable wireless then WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.If you are able to see password in * or # then you need o add new password but if you are able to read it then note down it then you can connect with it.
If you are not able to access router with above ip and user password then press RESET button for 10 seconds it is in back side of router.
Then you can access it with above method.
Jun 13, 2010 | NetGear WGR614 Wireless Router
When i connect my laptop into the modem it says local only and i cannot connect to the internet
http://192.168.0.1
or
http://192.168.1.1
Jun 13, 2010 | Arris SURFboard SB5120 Modem
Lost D-Link Disc
You need to configure your router again.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 02, 2010 | D-Link Xtreme N DIR-655 Wireless Router
How configurate this router? I lost the CD with configuration. Please ask me. Mabey in Polish language?:)
http://192.168.0.1
or
http://192.168.1.1
When you connect vpn router to wireless router set in wi fi lan property as your vpn network range set vpn router ip as gateway ip of wireless router.Then save settings and restart it.
May 20, 2010 | NetGear WGR614 Wireless Router
I am having trouble setting up the IP address to communicate with my router. I have followed the instructions in the manual provided with the router but when I test the IP address and error message appears...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Type user as "admin" and password as "admin" or "password" or "1234" or blank.
IF you are not able to access router still the press RESET button for 10 seconds it is in back side of router then try again with above..
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Mar 23, 2010 | Zyxel Prestige P-330W Wireless Router...
Hard drive crashed lost my dlink disc how would i put my dlink router on my new computer
http://192.168.0.1
or
http://192.168.1.1
Jan 13, 2010 | D-Link High-Speed 802.11g Wireless PCI...
Cant Access wet200 setup page ive changed my static ip still wont
Connect a LAN cable from your computer to the Linksys wireless router.
Setup a static IP subnet on your computer ip 192.168.1.xxx
make xxx= 20
Start your IE browser and type
http://192.168.1.226
Login as admin with a password admin
You can now configure the Linksys.
If you need a manual then click on this link to download the manual :-
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Sep 19, 2009 | Linksys WET200 802.11b/g Wireless Bridge
Secured on network
CHECK YOU LAN SETINGS,IT SHOULD HAVE AN STATIC IP TO SUCCESFULLY CONNECT TO YOUR ROUTER AND CONFIGURE IT.THE DEFAULT IP OF THE ROUTER IS 192.168.0.1.
Sep 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Symbol MC9090 Barcode Scanner Logo
1,788 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
