Question about RCA HD52W59 HDTV Projection Television
52 inch rca hdtv rear projection
Started showing a double picture and it is in a curved format, but turns off and on fine, what part do i need, can anyone tell me?
  • 5 more comments
  • holtbobby Nov 03, 2008
    can you tell me where the ic's are located at on my tv
    are do you have any pictures
    can someone tell me where the ic is located at?
  • Anonymous Nov 17, 2008
    52 in rca tv projecter does not turn on
  • squinn_728 Jan 22, 2009
    while watching t.v my screen curved inwards and the colour is off also..Is there a way to fix this problem?
  • jason May 11, 2010
    there may only be some bad resistor causing this you need to be able to do tests
    can you?
    do you know how to solder ? and identify bad components?
Replace fl231 dl231 and resolder the flyback.
Posted on Jun 08, 2010
  • 899 Answers
You will definately need a convergence done , but will also need some resistors replaced on it as well
just say if you need more help in getting this fixed
electech
Posted on Oct 31, 2008
  • 1 more comment
  • jason Nov 03, 2008
    this is on a big heat sink with letters starting with STK
    here is an example of what they look like http://www.nteinc.com/specs/7100to7199/p...
    just click the link to see
    but it is most likely that you will have a bad resistor on , thats why the stk failed
    electech
    sorry about that holtbobby ,been working alot , shoulld have looked better
    IBo001 , IB002 , IB003 , these are the color control IC's TDA 6118JF
    but here is what you need to do
    but of course your not having a color prob , but your vertical deflection booster (IF001)( TDA 8177) should be checked comming out of BL111 where the video board connects and resistors RF003 , RF004 , RF005 , RF006 , and DF011 also check RF020 and RF022
    not the dl032 ( diode) on the horizontal line
    if you want a schematic on your tv i can email you one if you want it
    electech
    also you may need this vertical booster http://www.nteinc.com/specs/7100to7199/p...
    let me know if you want that schematic
    Problem Solver:
  • 9 Answers
Replace the vertical output IC (DL032) on the deflection board. It is mounted on a heatsink, in the middle of the board. That is usually the culprit on the ITC222 chassis for bowing problems. Also, check the solder connections on the flyback transformer.
Posted on Nov 01, 2008
  • coreweave Nov 03, 2008
    electech,
    There are none of those IC's on the ITC222 chassis.
  • 4,234 Answers
This is a convergence problem that is either poor solder connections at the convergence ICs or defective ICs. These are largel black ICs attached to a heatsink that should be marked STKxxx. If you can solder, you can fix this yourself. Try resoldering the pins on the ICs. If that fails to resolve the problem, replace the ICs. It is possible that there will be additional components that require replacement as well. Please keep us posted on your progress. Also, since there are high voltages present even with the set unplugged, please be careful inside the set.
Dan
Posted on Oct 30, 2008
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52 inch RCA model # R52WH73. The picture is blurry and double. What do I need to do to fix it?
Ur convergence is dead,need a convergence kit,know how to solder right?Tries these websites.Tv Repair World.com,Ebay.com.
Oct 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture showing double and color off
There are poor solder connections on the flyback transformer and a small fuse is open. Pretty tough to repair this yourself but any tech can fix this easily.
May 13, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh73
Can you reply to this post and verify which model is your TV?
Jul 20, 2008 | Samsung PCN5425R 54" Rear Projection...
No Picture
where can i buy Deflection board for RCA D52W20
Jul 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
372 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
