FixYa.com
Tags:
Kenmore Oasis HE 27082 Stainless Steel Top Load Washer
Oasis - DU and LF error codes (by 3 users)
posted by kytroutmanoh on Sep 11, 2006
My first Oasis kept getting LF (long fill) errors.. they ordered a part that was on backorder for 3 weeks, so instead Sears replaced the washer with another identical one. I've had the replacement for 4 days and now I get DU (door unlock) error, and the lid will not unlock.
I've tried the cancel/stop button and unplugging for a few minutes and then plugging it back up and hitting cancel.. not working. My wet clothes are stuck inside. Any other suggestions before the repairman is called?
Comment by kytroutmanoh, posted on Sep 11, 2006
Cat,
Tried your solution of hold and release for 3 seconds.. and my husband tried.. it won't do it. It just keeps BEEPING and flashing DL. The books says DL will happen when there is weight on TOP of the lid..however, the book is wrong as there was NOTHING on the lid when it gave the error. But yes, a repairman has already been called and will be here tomorrow.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 02, 2008
have a LF error and it's sunday! of course i've got laundry to do and not a way to do it. i'm even more concerned now that i've read the previous comments.
Comment by dang alan, posted on Nov 02, 2007
My washer ATC ( auto temperature control ) is keep getting changing the select temperature during the cycle of washing. When the cyle washing is finish, we take the load out, close the door... late ter we heard the machine is still peeping. I just take out the power. What happen with my machine?
Can you explain? How I can fix it.?
Best Solution
Helpful (85)
catriver
Rank:Guru Guru
Rating: 94%, 2467 votes
Ky, see if you can put the machine in the service mode by doing this: turn the washer on, select any one button except for power,start and stop. press and hold it for 3 seconds--release for 3 seconds--press and hold for 3 seconds--release for 3 seconds--press and hold for 3 seconds....if you entered it correctly all the indicators will light for 5 seconds and 88 will show in the 2 digit display..It will now go into a automatic test cycle. If no faults are found it should unlock the top. This auto test will go through c0 to c9, you will see it in the display. If this all fails, you can access your wash by pushing in the clips on the left and right side front of the washer lid. The whole top will lift up. I would still call for service while it's under warranty. Catriver...post back.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
Kenmore Oasis HE 27082 Stainless Steel Top...
code ul appears shortly after...
machine show a ul code even... Answer This...
kenmore oasis long fill
what can I do before I call... Answer This...
recall on kenmore oasis
you mentioned in your post a... Answer This...
Kenmore Oasis washing machine...
I stopped my Kenmore Oasis... Answer This...
clothes jam into metal rim at...
I have a kenmore oasis model... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
