Santon R45 is not heating the water. Power is there and so is the water. Fixed 3 number in a building and they all have the same fault. Lost the papperwork so Santon warrenty was with all that.
Reset the 1st thermostat make sure this is above the temp' of the second
Posted on Jul 04, 2009
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
No win 98 drivers available for a HP officejet R45
If this driver does not work then most likely there is no driver. The first item should be the HP OfficeJet R45
http://www.soft32.com/s/Drivers/Miscellaneous/3-386-10-3.html
May 05, 2011 | HP OfficeJet R45
Xbox 360 shows (3) red lights around power button when attempting to power up. What type of fault is this and can it be fixed?
3 red lights is a hardware failure and to fix this you need to stop the heat build up getting to the main chips, you can use a good repair guide or you can send it in and they will fix it for you.
Sep 11, 2010 | Microsoft Xbox 360 Console
Hot water coming out of overflow, valves all been checked. Santon unvented heating system help!!
this wil happend with heating ??
if yes look for thermostat on boiler and turn it a little back then wil heater worming up only not to the max heating so then you do not need overflow outlet never leaking again out of overflow
Nov 08, 2009 | RTO SantonĀ® Tankless Hot Water Heater -...
My benq joybook r45 won't boot. the battery is fine.. the screen will go brighter/dimmer.. and attaching an lcd doesn't work.. what is wrong with this machine?
a number of things could be wrong- bad ram, bad motherboard. a bad hard drive will still usually get you a post screen. if you are at least getting a post screen, i would look towards hard drive issues.
Oct 31, 2009 | BenQ Joybook R45 - R45-PE-16, Intel Core...
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Bosch Exxcel Type S9N61B
IF YOUR DISHWASHER IS OVER 3 YEARS OLD IT HAS PROBABLY BLOWN THE HEATER IF THEY ARE USED ON REPEATEDLY LOW TEMP WASHES FAT CAN BUILD UP AND DESTROY THE ELEMENT ON A 35 QUICK WASH IT SHOULD HEAT UP WITHIN 12 MINS OF STARTING IF NOT HEATING APPLIANCE WILL WASH FOR UP TO 3 HOURS IN COLD WATER IF CYCLE TIMES ARE NORMAL BUT NO HEAT IS EITHER A THERMOSTAT OR PCB FAULT THE FORMER IS LESS LIKELY,YOU SHOULD GET AREADING OF AROUND 25 TO 30 OHMS ACROSS LIVE AND NEUTRAL AND INFINITY ACROSS LIVE TO EARTH AND NEUTRAL TO EARTH.
HOPE THIS HELPS
Jul 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Hot water is running very slow
Definitely calcium is your problem. If you want to work on this your self turn off the power and drain the tank into a bucket, you will find lots of calcium in the tank. Rinse it out a couple times with fresh water, and vinegar.
May 07, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
