Question about Konica Minolta magicolor 5430 DL Laser Printer
Konica Magicolor 5430 DL Fatal Error Code: 0300H
Does anyone know what this code means? It is no where in the manual and I can't find anything online. The printer was working fine, and all of a sudden stopped printing and now says on the printer panel code: FATAL ERROR CODE: 0300H Can anyone help?
    Champion:
  • 214 Answers
0300H: Polygon Motor malfunction
try restart if not helping then there can be problem with ph unit or PWB-A board
Posted on Jun 19, 2008
Konica Minolta Magicolor5440DL Error Code
error 0094h = 2nd image transfer pressure/retraction failure
basically it means that either a sensor or cable is not fitted supposedly and reseating could possibly solve the issue.
you can research the error code in the following service manual:
http://printer.konicaminolta.com/drivers/other/Manuals/5400/smfs_54.pdf
Mar 09, 2010 | Konica Minolta magicolor 5440 DL Laser...
Konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Apr 18, 2009 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 5430DL fatal error code: 004EH
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
Fatal Error 12H on Konica Minolta Magicolor 2430DL
This error (12H) pertains to the Laser Unit of the printer which is damaged and needs to be replaced. The Laser Unit is the heart of the printer, it's what transmits the image to be printed. You need to contact a service center and will run you about $200. I had this same problem with my printer and had to call Technical Support and they gave me the bad news
Oct 26, 2008 | Konica Minolta magicolor 2430 DL Laser...
Minolta Magicolor 2430 DL
Fatal error code 2AH: Faulty memory data.
1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
3 - Change PWB-A. (8314139-0101-15)
4 - Change Parameter Chip.
hope it helps
regards
Sep 14, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 5430dl colour printer
13D0H: Parameter Chip failure
the PWB-A may be faulty.
May 21, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Nov 28, 2007 | Minolta magicolor 2300W Laser Printer
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Waste: near full
take the waste bottle out & empty it. I have never had to buy a new one.
Aug 30, 2006 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 5430 DL Laser Printer Logo
513 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
