Question about Sony Ericsson Walkman® W880i Cellular Phone
Fault phone speker and mic does not function
Mic problim
If there is no sound heard by the caller then it is possible that the mic of the phone is faulty. You have to check if the mic port is clogged with dirt and so blocks the mic. If so remove panel and clean.
Also you can confirm by using a handfree on the phone. If the head set mic works well there is no fault on the phone motherboard and the solution can be a new mic or a faulty external terminal which can be cleaned.
Dec 20, 2011 | Cell Phones
Put new pa speakers in church 2 1000 watt tied 2gether and 2 300 watt. tied 2gether. the pa amp only has 250 watts with 6 mics connected and a cd player which plays fine. every time the mics are used if...
hi,
You have to check the ohms of the speakers all spekers should be 8 Ohms or above. if not it will overload the amplifier at high level. The minium ohms impedence of the amplifier is 4 ohms. If you connect two 8 ohms speakers together then the effective ohms will be 4 OHMS then the amp will handle the speakers. If you connect two 4 ohms spekers together then the effective ohms will be 2 Ohms, this will overload the amplifier. You will be able to connect two 8 ohms speaker to left channel or right channel of the amplifier. Check the speaker spesifiction to know its ohms. Make sure all the speakers have an impedence of 8 OHMS or above
OK
Aug 19, 2011 | Radio Shack 250 Watt PA Amplifier...
When calling another phone i hear the party but they can not hear me
This is due to one of two reasons.
It is either your phone is on mute or you have a broken mic.
You should try to make a call and ensure that the mic is not on the mute setting. This will prevent the receiver from hearing whatever you are saying as it will render the mic inactive unless you deactivate this function and make the mic work.
On the other hand, you may have a faulty mic that needs to be repaired or replaced. If this is the problem, you have to take it to a repairer who would help you examine the mic and detect the exact fault. It should not be very difficult to replace the mic depending on the type of phone you are using.
Hope this helped you? Please comment for more information and thank you for using FixYa.
Jan 30, 2011 | Cell Phones
Mic problem i change mic but it not working
The fault can be the mic input amplifier which is not working to increment the signal to the desired level to be fed into the circuit.
So you will need to trace the signal path if you are confirmed with the mic connection and type.
It is fault in the mother board.
Jan 21, 2011 | Nokia 2690 Cell Phone
Ringer problem
Hai, if you see symbol headset on display screen, open your set, clean that pcb on charger n connector area, some time this happen during splash water. if pin of connector do not tuch on board, headset or car symbol will be apear on screen, ringtone cant be function thru loud speker..
Aug 04, 2010 | Nokia 1600 Cellular Phone
Headphone & mic problem
i am also facing same problem.... any idea....
Sep 06, 2008 | Compaq Presario 700 470024-192 Notebook
How to activate mic phone
Feature 1 or function 1 will work
Mar 04, 2008 | NEC Electra Professional ETW-16DC-2
Mobile
have u droped it if yes there r really dalicat speker wirring in it ,might be speaker wirre is come off u going to say ,how come othere people cant here me ,answer is that is unfortunatly one wire given power to speeker and mic.so if u leaving near me i can fix for u but ,bad for u .
Jan 13, 2008 | Samsung SGH-E900 Cellular Phone
Sony Ericsson Walkman® W880i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
