Question about HP LaserJet 4250n Printer
Poor quality smudge and ink blotting marks in the centre of any printed document
Everytime we print a document, the ink smudges in a number of places, particularly in the centre of the document. We have run the printer cleaning process a number of times and it doesn't seem to make much of a difference. When we look at the fuser, it appears as if the roller has a clear film over the centre of it, where its smudging. Should we just buy a new fuser or is there something else that might be causing this?
Thanks in advance.
  • laaim Oct 30, 2008
    Pls note this is a HP4250n printer. thanks
    Thank you very much.
    Sniper:
  • 87 Answers
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
Posted on Oct 30, 2008
HP 1600 prints with left side smudging
If you are ask printer paper Quality then first you check it ink label and then you check paper quality because both are depend which types of quality you are used. If one in dull then printer quality also dull. I share a print quality related link please read and follow instruction.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01691481
Thanks,
HP Printer Support
Apr 04, 2014 | HP LaserJet 1600 Printer
I have a lexmark X4650 and the quality of the printing suddenly went very poor. Smudged and not clear at all. The printer is not used heavily and I have tried alligning the cartridges and cleaning to no...
Try to check the ink levels and make sure it's good for printing. Otherwise, please replace them with new cartridges. You can try to re-seat the cartridges in the printer then try to print your document again to verify that the print quality has improved.
Aug 14, 2011 | Lexmark X4650 All-In-One InkJet Printer
Cleaning inkjet nozzles
Here's what I found here:
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Cleaning the print cartridge nozzles
To improve print quality, you may need to clean the print cartridge nozzles.
Clean the nozzles when:
• Characters are not printing completely.
• White dashes appear in graphics or printed text.
• Print is smudged or too dark.
• Colors on print jobs are faded or they differ from the colors on the
screen.
• Vertical, straight lines are not smooth.
43
You can use the operator panel or the Lexmark X5100 Series Solution
Center to clean the nozzles.
Using the operator panel
1 Load paper in the All-In-One. For help, see page 16.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 To further improve print quality, try wiping the print cartridge nozzles
and contacts (see page 44), and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
1 Load plain paper in the All-In-One. For help, see page 16.
2 Click Start Programs Lexmark X5100 Series Lexmark X5100
Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
clogged nozzles.
6 Print your document again to verify your print quality has improved.
44
7 To further improve print quality, try wiping the print cartridge nozzles
8 If print quality has not improved, try cleaning the print cartridge
Wiping the print cartridge nozzles and contacts
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges. For help, see page 38.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Hold a clean, damp section of cloth against the contacts for about
three seconds. Gently blot and wipe dry in one direction.
Nozzles
Contacts
45
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print cartridge
8 If print quality is still unsatisfactory, replace your print cartridges. For
help, see page 38.
Jun 29, 2011 | Lexmark X5150 All-In-One InkJet Printer
Printer is printing two smudge marks on my documents.
Two parts of the printer can affect this.
1) the toner cartridge
2) the fuser
Testing can be done to determine the problematic part.
Do a print using manual feed. Once the last bit of paper goes into the machine, open the printer door.
Remove the toner to check if smudge is there.
Replace toner cartridge if there is smudge, replace fuser it not.
May 29, 2009 | HP LaserJet 3330MFP All-In-One Printer
Prints smudged documents
I don't know for sure that it will help, but try to work through the Hp troubleshooter for your printer and see if you can't come up with a solution
Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | HP LaserJet 1300 Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer has two smudges in same place every time
The reason you see a smudge in the exact same place everytime is due to ink being on the roller. Solution: using good light, use isoprel alchol on a cotton swab to clean the roller. Ink on the roller is also an indication that your head cleaner pad (look really good on the right hand side <inside> for the pad) is dirty. If you've not done so in the past, just flip it over and like magic you have a clean pad...just dirty on the other side.
Dec 17, 2008 | Dell 924 All-in-One InkJet Printer
VersaJette m300c printer smudges
I am having the same challenge with the smudging. I get the wet the print cartridges but that doesn't work. I have to run some documents through which wastes the ink. I am totally disappointed with this printer. I tried Canon when they had that one as a special deal. I ran through 3 or 4 heads and Canon said not to use the MICR ink. Makes no sense to me. G7 won't respond to me anymore. I now have a Vista and it looks like that will be a challenge and I have an ink cartridge sitting in my closet for this dang thing. How disappointing is this.
Oct 30, 2007 | G7 Productivity Systems VersaJette M300...
HP LaserJet 4250n Printer Logo
869 people viewed this question
Seeker5211
Seeker5211
