Question about Nokia 1600 Cellular Phone
I don't remememeber my security code
Not working screen due to security code problem
  • 89 Answers
Please give me your imei no.
you can see it on the back of youf phone after removing battery.then i will gve you the security code.
Posted on Oct 30, 2008
How do I bypass the Security Code on my Lg GS390 if I don't have a AT&T SIM card?
try a reset. usually can use 0000 for a temp security code until you reset it
Sep 25, 2012 | LG Gs390 Cell Phone
Forgot my flip camera security code
  • 1 Enter the number you think is your 4-digit unlock code. Do it once slowly, so you don't waste the number of tries you're allowed before the cam completely locks. If you never set a code, try 1234. The factory sets this as the default. If that fails, try the last four digits of your home phone number. That's the default of some network providers. If all these fail, go to Step 2.
  • 2 Click the menu key, which has horizontal lines on it. It sits between the left and right soft keys and above the round 5-way navigation keys. You should now see the unlock code bypass screen. Enter your 6-digit security code. Select "OK." If this doesn't work or you don't remember your security code, go to Step 3.
  • 3
  • Try 000000 as the factory default setting for the security code. If that doesn't work, go to Step 4.
  • 4 Call your network's customer service center. Locked ones usually let you call both customer service and 911. However, calling on a separate phone will make entering the code they give you easier to enter and test while they're still on the phone with you.
  • HID KITS.
    Jun 01, 2012 | Pure Digital Flip Video Camcorder
    The screen does not turn off when i don`t use the mobile
    You Might have increased Your Back light Time Up to much time...So should Turn it for lesser time..
    if it doesn't work then Restore your phone to factory settings.
    for his go to setting then to "restore Factory Settings" and enter The security code.
    if u don't have security code check it in your phone's manual.
    Jan 08, 2012 | Cell Phones
    Forget my nokia 1200 security code ple help me
    Hello! Welcome to FixYa
    First try Default security code of Nokia i.e 12345 or 00000.
    If you have changed your code before then to get your Master code. Type *#06# at the mobile screen to know IMEI no of your mobile or open back cover and pull out the battery and see the IMEI Then Go Here.
    Give your IMEI no there and calculate your master code and try it.
    If it don't work then contact to Nokia service provider
    Further assistance, I am here to help
    Thank you for using FixYa
    Aug 30, 2011 | Nokia 1100
    I dont know how to set up the nintendo wi-fi connection
    1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
    2. Tap "Connection 1 None."
      emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
    3. Click on "Search for an Access Point."
    4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
    Once you have done this you may find next to your wi-fi, a lock this is what they mean:
    unlocked_g.png No security - Your wireless network is unlocked.
    1. Tap on your network name to select it.
    1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
    • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
      • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
    wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
    1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
    wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
    The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
    Jul 05, 2011 | Nintendo Video Game Consoles & Games
    I have lost my phone security code nokia 5200
    Hello and Welcome to FixYa!
    The Default
    security code of Nokia is 12345 or 00000.
    If you have changed then to get your Master code. Type *#06# at the mobile screen to know IMEI no of your mobile or you can also see the IMEI no after pulling out the battery, It is mention at back side of the mobile Then Go Here.
    Give your IMEI No there and calculate your master code and try it.
    It will work as your security code If it doesn't work too then you can get online paid security code for your cell. If you want to then you can Go Here.
    After getting your Cell info and charges, they will send you code.
    If you don't want to then you can contact to NOKIA SERVICE PROVIDER to solve your problem
    Apr 26, 2011 | Computers & Internet
    Security code problem
    hello
    1_ can you save your formation in other phone .
    2_that code format your phone for Nokia only
    3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
    4_ other numbers *#7370# and the security n ......
    and look if the problem is solve it
    because after this . you have like a new mobile
    Jan 23, 2009 | Nokia 6288 Cellular Phone
    DON,T KNOW MY 3 PRIVACY CODE NUMBERS
    This tip unlocks the 3 digit security lock.
    1. at the same time hold the menu button (top left) and the jump button (bottom left)
    2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
    3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
    4. The phone will reset and clear/unlock the security code
    http://shop.sidekickskin.net/Sidekick-Tips-Tricks
    Mar 31, 2008 | T-Mobile Sidekick ID Cellular Phone
    Nokia 1600 Cellular Phone Logo
    20 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
