Question about Denon AVR-5805 Receiver
Front right speaker sounds distorted
Frs sounds distorted, I´ve tried replacing the speaker with a new one but it did not work
    Problem Solver:
  • 8 Answers
Check all wire connections, check all wires for frays make sure none of them are chaffing on any sharp metal, try different cable or wire between the tuner and or amp and the speaker sorry to say but it sounds like you possibly may have shorted out a Chanel. not saying you did but you may have. you may have to open the system smell the circuit board, to see if there was any (magic smoke), if so you can try to replace any of the bad components check and try to repair any opens, or try to find any loose solider connections or any burnt resistors or fluid leaking from capacitors if all is well and you don't find anything which you probably will if ya blew a Chanel, have it repaired, or buy a new one or go to EBay............
Posted on Oct 30, 2008
My 787 receiver is 10 years old. It worked excellent all these years . It developed distorted sound in the front left channel. I swapped speakers and confirmed that the problem is with the receiver front...
The problem will be in the power amp for the the left channel. One you have identified this on the circuit board you can compare the channel with the right. As they are both the same. Start with a visual check. If anything looks odd compared with the the right replace it. Distortions are often caused by a burned resistor. Though the main power transistors or IC can cause it too. If you can't find anything visual I would replace the main output device(s) for the left channel.
Nov 21, 2017 | Audio Players & Recorders
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
Hi i am having problems with my lg home theatre system. The front right speaker will every now and then make a loud distortion noise like static and its annoying. I,ve tried new speaker wire, new contacts...
Hi.
First make sure all connections are firmly in place. Not only speakers, but any other inputs too.
swop the left and right channels over at the amplifier end. If the sound happens on the other speaker now, you have a faulty av receiver. If it's still on the same speaker, that speaker is "broken" and requires replacing.
Jan 14, 2011 | Audio Players & Recorders
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Distortion
The wattage rating, I take it, for the speakers is more than 45 watts right? Check to make sure that you connected the right wires to each speaker,front right + wire to front right speaker, not front right +, to front left + and make sure that the -'s are connected to the -'s, and the +'s are connected to the +'s.
Mar 29, 2010 | Alpine SXE-1325S Coaxial Car Speaker
I have a problem with my car speaker/tweeter
Sounds like you have the ground and live possibly the other way around from the head unit to the speakers. The reason for you hearing it from both the tweeter and the speaker is that the tweeter is connected in parallel to the speaker.
Swap the wiring and try it.
Mar 21, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
MID-RANGE DISTORTION
hi it is an amp module failure inside £129.00 plus vat 4 hours to replace total strip out £380.00 total to do these are made by samsung and rebadged horrible things dump it thats my advice regards kirk
Oct 14, 2008 | Denon AVR-3806 Receiver
Denon AVR-5805 Receiver Logo
100 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
