Question about Honeywell Heating & Cooling
Need wiring diagram to include: Underfloor heating downstairs (wet system,polyplumb) combi boiler for the heating and hot water
  • wj_electrics Oct 30, 2008
    Underfloor heating is:master 4 zones PB1ZP(polyplumb)
    Combi boiler is:BAXI,Duo-tec combi HE
    Genius:
  • 2,035 Answers
Please mention model number of the Air Conditioner?
Posted on Oct 30, 2008
  • 1,183 Answers
could you provide the exact model number or the product you need the wiring diagram for
Thanks
Proton
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
How do i connect a standard room stat to my combi boiler
Honeywell stats, esp the rounds ones, have multiple wiring diagrams that come with them including those for radiant which is a boiler hookup.
The stat has to go through the zone controller as your combi has a P1 zone priority set for the water heater and other P2-P? zones for heating loops. TACO will help you with this but it'd be really cool not to be so cheap you don't call a Tech for a Service Call to do a professional's job.
Oct 20, 2014 | Water Heaters
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
Sep 23, 2014 | Water Heaters
Water fluctuating hot and cold on a shower run off a combi boiler
could be a number issues 1 the hot and cold water supply going to shower could be of unequeal pressure thus the fluctuating 2the heat exchanger in your boiler is conjested with debris 3 the gas bed in boiler is cross burning giving an unbalanced "heat pick up"out put !2 &3 would apply if your on a combi boiler system .if your on a conventinal system you could be pulling air from the head of the cyclinder ,
Jan 19, 2011 | Home
To get heat downstairs i have to turn raiators off
Hi check the water pressure in the boiler check the setting / speed of the pump see if this helps
Feb 07, 2010 | Desa International CBN30T Central Heating...
I can only get heating to the radiators upstairs, not downstairs
balance the rads.
upstair radiators turn all valves off,heat will then divert downstairs,open valves upstairs 4 turns on locksheilds and number 4 on trvs if u have any.
then if that does not work get a combi or powerflush.
if u cant afford then drain a little from rads,get x300 sludge remover from plumb shop and put in header tank(not hot water tank).
then fill system up and repeat balancing.
www.jollygreenplumbingmachine.co.uk
Dec 26, 2009 | Desa International CBN30T Central Heating...
Radiator heats up when running a shower.
Your boiler is overdue for a service.
Combi boilers are unlike regular boilers in that they have quite a few moving parts, it's vital that these are serviced annually if you want the boiler to remain reliable and to avoid expensive failures.
In your case, the diverter valve has most likely failed. Normally, when the heating is on this senses when there's a demand for hot water and temporarily diverts the primary hot water circuit to feed the domestic hot water heat exchanger. When the demand for hot water ceases the primary hot water circuit is diverted back to the central heating heat exchanger. The valve has a number of moving parts including a rubber diaphragm which can wear out and split and moving shafts which can seize.
When the valve fails it can leak and also can divert hot water to the central heating heat exchanger when hot water is used. The reason that only the highest radiators in the system are affected is probably because the failed valve does not necessarily cause the central heating pump to activate and circulate the hot water throughout the system (it does on some boilers though). If hot water is introduced into a cold heating system it will rise via convection to the highest points in the system like an old fashioned gravity circulation system which was unpumped.
Call a heating engineer out as soon as possible; I'm not going to advise how to do the repair yourself as gas appliances MUST be serviced by qualified persons only for reasons of safety. If you're lucky then the valve simply needs cleaning up and a few new diaphragms plus other minor seals and rings. If it's gone too far then the valve and possibly the manifold it's attached to will need to be replaced.
In the UK the part alone typically costs between £100 to £200 depending on whether it's just the valve or the manifold as well. The diaphragm kit typically costs up to around £15 and is routinely fitted when the boiler is annually serviced, and a new valve will already have new diaphragms fitted. For a routine service expect to pay for up to two hours labour (many can be done in one hour), but if the valve/manifold have failed it will be longer as one failure often causes other parts to need further inspection/repair.
I hope that I've helped you today, if so please return the favour by rating my answer.
Jul 10, 2009 | Whirlpool Aquatic Millennium VII -...
Baxi 80 e some rads hot others cold
is the pump running or is there an air lock near to the boiler check water tank in loft the smaller one to make sure you have water in the system
Apr 24, 2009 | Combi Centre DX - Mango
Boiler keeps losing pressure when the heatings off
Hi Leehardcast,
Yes the problems are related. The system is low on water. So now instead of water you have air in radiators which is easily compressed when it heats up. Then pressure loss when it cools down.
Add some water to your system until you have 15lb pressure and bleed out upstairs radiators at the same time.
Please rate this response and Good luck, Phil
Jan 13, 2009 | Watts 3/4 Pressure Relief Valve
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Heating & Cooling Logo
494 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
