Question about Vivitar ViviCam 3915 Digital Camera
No picture on screen
The camera turns on and i can use the menu but there is no picture of whats being seen .
  • 1 more comment
  • mymatenicky Aug 29, 2008
    I have this same problem have tried this solution but cannot get it to open
  • Anonymous May 11, 2009
    vivitar vivicam 5199
    i have the same problem but with a different camera vivitar vivicam 5199
    Scholar:
  • 32 Answers
Aside from the sliding lens cover, there is a tiny lens cover electronically opened when camera is power on. Check to see if it's not opening. If so, give the camera a snap to the surrounding of the lens part and try to turn on again.
Posted on Sep 14, 2007
How do I set up my camera for a timed picture?
You didn't say what model you have but often it's in the menu settings or there is a feature seen on the screen or camera knob that shows a small clock face.
Oct 18, 2014 | Cameras
IMAGE IS NOT SEEN ON SCREEN BUT MENU IS SEEN
The CCD censor or circuit is faulty. Needs camera shop.
Dec 19, 2012 | Kodak EasyShare C613 Digital Camera
Menu is seen but picture is not seen on screen
Hello, Will it take a photo ? Sounds like bad sensor unit. High dollar repair.
Best Regards, Russell
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
When i turn on the camera the lcd screen is black and when i turn off the lcd the viewfinder is also black, no objects are seen, menu items can be seen but no objects
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 20, 2010 | Canon PowerShot S2 IS Digital Camera
Camera menu screen works but camera will not take pictures and screen does not light up in camera picture taking mode
Oct 14, 2009 | Canon PowerShot A610 Digital Camera
I cannot get the LCD view screen to work ?
There should be a menu button on the camera. if there is, go into the settings and turn the LCD Screen back on. (Actually if you press the menu button on the camera, you should see the menu on the LCD screen.) There is an option to turn off the screen to save battery life.
Dec 17, 2008 | Nikon D70s Digital Camera
Camera screen is black at start up
You should reset the camera. This is a fairly easy procedure which involves either going into your setup menu and choosing "reset" (or intialize), holding down the menu key for 5 seconds, or, removing the batteries for a few minutes. It may be that the firmware loading got corrupted and the camera just needs to be "rebooted," which is something that turning it on/off won't accomplish. But after which, you should have the camera reset to factory default settings.
Sep 25, 2008 | Canon Cameras
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Vivitar ViviCam 3915 Digital Camera Logo
76 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
